Posted September 10, 200915 yr [Addon] HyperSnap 6.61.05.cab*Addon from retail. No crack, no Serial need! Works with nLite and RVMi. HyperSnap 6 is the fastest and easiest way to take screen captures from Windows screen and text capture from places where system text copy is not possible.Windows 98/ME/NT4/2000/XP/Server 2003/Vista/Win7 (x86)/(x64)" If you want to preserve your own settings, extract to a folder, USB Stick, etc.Then run HprSnap6.exe from there.Changes in v6.61.05, 2009.08.17: * Fixed: pasting a 32-bit image into HyperSnap and then saving a 32-bit PNG image would result in incorrect transparency of the final PNG file. * Pasting an image extending beyond the bounds of current picture in HyperSnap will now enlarge the current picture if "no clipping" is selected. * Automatic saving of screen captures (Quick Save) with file numbers incrementing will now "skip" over existing files, instead of overwriting them. * Yet another improvement in auto-scroll code, now compares the captures before and after each scroll from two different places to improve reliability. "*** Text by FreeRyde (Thanks for sharing, Mr. Freeee!) ***Homepage: http://www.hyperionics.com----------------------------------------------------------------------Download: http://www.4shared.com/file/131507374/6c16fd89/Addon_HyperSnap_66105.htmlMD5: BC9B59CC50A95B7E4EE56DC6FF0D597ASize: 5.67 Mb
