Don't know if somebody might be aware of this or not but i thought to share it.
Just think you are doing some important work and or downloading a huge file and its going to complete the download process but in between the Error Message Comes The System is shutting down, In that case what to do.
Some times we need to stop some restart process quickly. In windows XP some times it gives auto restart warning and here is good solution for it.
Stop A Restart Process In 3steps :-
1. Go to Start menu
2. Click on RUN
3. Enter the following command excluding hashcodes "shutdown -a"
Simple but very useful when you don't want your pc to be started.
Enjoy. :thumbsup_anim:
Edited by MANIKANT.S.GUPTA
