Hey,
I cant figure out how to delete some icons from the desktop:
DEL /S /F /Q "%UserProfile%\Bureaublad\VLC media player.lnk"
DEL /S /F /Q "%UserProfile%\Bureaublad\QuickTime Player.lnk"
DEL /S /F /Q "%UserProfile%\Bureaublad\Malwarebytes' Anti-Malware.lnk"
DEL /S /F /Q "%UserProfile%\Bureaublad\Adobe Reader 9.lnk"
DEL /S /F /Q "%AllUsersProfile%\Bureaublad\Adobe Reader 9.lnk"
DEL /S /F /Q "%AllUsersProfile%\Bureaublad\Malwarebytes' Anti-Malware.lnk"
DEL /S /F /Q "%AllUsersProfile%\Bureaublad\QuickTime Player.lnk"
DEL /S /F /Q "%AllUsersProfile%\Bureaublad\VLC media player.lnk"
DEL /S /F /Q "%AllUsersProfile%\Desktop\Adobe Reader 9.lnk"
DEL /S /F /Q "%AllUsersProfile%\Desktop\Malwarebytes' Anti-Malware.lnk"
DEL /S /F /Q "%AllUsersProfile%\Desktop\QuickTime Player.lnk"
DEL /S /F /Q "%AllUsersProfile%\Desktop\VLC media player.lnk"
DEL /S /F /Q "%UserProfile%\Desktop\VLC media player.lnk"
DEL /S /F /Q "%UserProfile%\Desktop\QuickTime Player.lnk"
DEL /S /F /Q "%UserProfile%\Desktop\Malwarebytes' Anti-Malware.lnk"
DEL /S /F /Q "%UserProfile%\Desktop\Adobe Reader 9.lnk"
Thats what I tried, I also tried just DEL without switches, but it aint working.
I tried Desktop (ENU) and Bureaublad (NL), I am using NL Windows 7.
Maybee an other way, making addon that deletes them or.. ?
Edited by Raoul
looks like you might no be admin, try removing @echo off and putting a pause at the end to see what error is returned.also why not do:
cleanup.bat
DEL /F /Q "%UserProfile%\Bureaublad\*.lnk"
DEL /F /Q "%AllUsersProfile%\Bureaublad\*.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Bureaublad\*.lnk"
note that i have removed the /s switch as you are giving it the full path thus dosent need to erase in any sub dir.Plus i added the 3rd line as its a new desktop path that is kinda like allusers/desktop.And remember ure batch file will ahve to be run as admin.
if ure running the batch as part of an automation then ull ahve to provide a user name which is an admin and call the "cleanup.bat" or what ever ure going to name it.
runpromoted.bat
runas /user:SOMEADMIN /savecred cleanup.bat
you will have to enter the name of the admin account of the pc here > SOMEADMIN
also the "/savecred" switch is optional, it keeps you from having to re-enter the account password a 2nd time if the batch is ran later.
if its being ran from a cd then ull have to change it like so:
SET CDROM=%~d0
runas /user:SOMEADMIN /savecred %CDROM%\cleanup.bat
I run it from FirstLogonCommand in Autounattended.xml.
But I dont want to remove all icons, just the ones I pointed out, so not the *.lnk.
Will try it with the PAuse, to find out the error.
ok, but i am prety sure its cause of admin privileges.
Hi Raoul Please use this script
I Found On The Msfn That Is Move All Shorcut From Desktop To other Folder
This Script Moving All Shortcut To 333
CleanUpShortCuts.rar
Thanks but I dont want to delete all of the icons.
Just did this:
DEL /F /Q "%UserProfile%\Bureaublad\VLC media player.lnk"
DEL /F /Q "%UserProfile%\Bureaublad\QuickTime Player.lnk"
DEL /F /Q "%UserProfile%\Bureaublad\Malwarebytes' Anti-Malware.lnk"
DEL /F /Q "%UserProfile%\Bureaublad\Adobe Reader 9.lnk"
DEL /F /Q "%AllUsersProfile%\Bureaublad\Adobe Reader 9.lnk"
DEL /F /Q "%AllUsersProfile%\Bureaublad\Malwarebytes' Anti-Malware.lnk"
DEL /F /Q "%AllUsersProfile%\Bureaublad\QuickTime Player.lnk"
DEL /F /Q "%AllUsersProfile%\Bureaublad\VLC media player.lnk"
DEL /F /Q "%AllUsersProfile%\Desktop\Adobe Reader 9.lnk"
DEL /F /Q "%AllUsersProfile%\Desktop\Malwarebytes' Anti-Malware.lnk"
DEL /F /Q "%AllUsersProfile%\Desktop\QuickTime Player.lnk"
DEL /F /Q "%AllUsersProfile%\Desktop\VLC media player.lnk"
DEL /F /Q "%UserProfile%\Desktop\VLC media player.lnk"
DEL /F /Q "%UserProfile%\Desktop\QuickTime Player.lnk"
DEL /F /Q "%UserProfile%\Desktop\Malwarebytes' Anti-Malware.lnk"
DEL /F /Q "%UserProfile%\Desktop\Adobe Reader 9.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Bureaublad\VLC media player.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Bureaublad\QuickTime Player.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Bureaublad\Malwarebytes' Anti-Malware.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Bureaublad\Adobe Reader 9.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Desktop\VLC media player.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Desktop\QuickTime Player.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Desktop\Malwarebytes' Anti-Malware.lnk"
DEL /F /Q "%systemdrive%\Users\Public\Desktop\Adobe Reader 9.lnk"
One of them did the job. :P
