Hi guys
Can someone please tell me where the cursors are located in the xp CD?
I was looking for a compressed .cur and .ani files in the i386 directory but found nothing.
It must be inside some other file like dll.
I need this because i want to replace the classic xp cursors with new ones in my custom xp cd.
Fixit is right. (it's in i386 folder)
xzappa, try to use some file search utility to search. It is much easier to search in i386 folder as it contains a lot of files.
