how i can kill processes services (Windows Security Center Service) by cmd
& haw ican disable thes by cmd
thx to all
Edited by waleder
Make a backup the SFC_OS.DLL in the C:\WINDOWS\SYSTEM32 directory.
Make an additional copy of SFC_OS.DLL called SFC_OS1.DLL and open it in a hex editor.
Windows XP (no Service Pack)
At offset 0000E2B8 (0E2B8h) you should find the values "8B" and "C6".
Windows XP (Service Pack 1)
At offset 0000E3BB (0E3BBh) you should find the values "8B" and "C6".
Do not continue if you are unable to find these values.
Change the values "8B C6" to read "90 90" and save the changes.
Run these commands to update the system files:
copy c:\windows\system32\sfc_os1.dll c:\windows\system32\sfc_os.dll /y
copy c:\windows\system32\sfc_os1.dll c:\windows\system32\dllcache\sfc_os.dll /y
If you are prompted to insert the Windows CD, click Cancel.
Restart Windows for the change to take effect.
Once these files have been updated apply the registry setting above.
Note: You must manually modify the operating system files using a hex editor to allow this tweak to disable SFC on Windows 2000 (SP1+) or Windows XP.
Edit: I've just noticed your post was how to do it in CMD. Sorry.
how i can kill proposes services (Windows Security Center Service) by cmd
I'm sorry i typed wrong
Of right
thx for help to all
well what do you mean
if you mean the service in the task manger beside the process
then i think i have a small tool that can do that
http://www.dynawell.com/download/reskit/microsoft/win2000/netsvc.zip
when you want to do something
you will need to use this commands
netsvc \\%computername% /list << this will list the Service
netsvc \\%computername% /stop "Service name" << this will Stop the Service
to start replace stop with start
Edit:
found another way using internal tool
sc stop "Service name" << that will stop the service
and to start type start
Edited by DaRk MaDnEsS
