[Addon] Cab Maker V 3.3
Feature
1-Right Click on a Folder and Send To --> Cab Maker [will Compress the inside the folder (only Files)]
2-Right Click on a Files and Send To --> Cab Maker [it will try to extract it if it's a cab file] or [it will compress it using MakeCab]
3-Right Click on a Multi Files and Send To --> Cab Maker [it will Make a cab file that have them]
Download-(32Bit-64Bit)
MD5:3E66515F3F443A5B25B8BE1063A30DCA
V3.1 Download here
ChangeLog
4-12 V3.3
Rewritten the hole code to run with cabarc only for higher ratio
Now when compress files in a folder the cab gets the folder name
-Removed the hole gui since i don't use makecab no more until i find a better way with cabarc
8-10 V 3.1
you can close the cab compress and it will close makecab by it self
if the File ended with _ the extract would be in the working dir
5-10 V3.0
New Gui With Progress Bar
Sub Folder maker now is supported
Fixed cabbing file more than 650 MB
3-10 V2.5
Compression Memory is Now 21
fixed spelling error thx to user_hidden
1-10 V2.1
Compress Using LZX for higher compression Ratio
fixed period issue pointed by ricktendo64
29-9 V2
Removed CabArc (Using MakeCab and Extract Now)
Added a new way to know Cab files from none
ReWriting the hole code
Edited by DaRk MaDnEsS
  • Replies 60
  • Views 40.8k
  • Works great...only one small thing, does not work for folders with period <.> in the filename example: "Folder.Example" Edit: and you may want to use better compression, I dont know the exact sw
  • Hi, DaRk MaDnEsS Just a suggestion. I added this tweak to give faster access to cabmaker3 w/o waiting for sendto menu to appear. [1stLevelContextMenu.AddReg] HKLM,"SOFTWARE\Classes\*\shell\Cabmaker3"
Good Work Thanx :D
thankyou very much
Version 2 is out
for 64 bit users
the release for them is soon
be patient
and thx for every one Post
Holy Crap! If this can make multiple files into a single .cab under Win7 x64 you'll have my undying gratitude!
I can finally get rid of TugZip.
well yeah
only one thing i couldn't do
is adding a folder
makecab doesn't support that
(and by the mean of adding folder i meant that
you can't make a cab that have a folder in it
TuGzip can do that and i'm trying to find a way to do that
if you right click on a folder and send it to CabMaker
it would add the files in it)
you can try it your self
just use the version in here and replace in the inf
every 11 with 16425
to install it to syswow64
then it should work
but i just need someone to confirm that
Edit: and you may want to use better compression, I dont know the exact switch to achieve the best cab compression with makecab/cabarc but I am sure somebody else does
Works great...only one small thing, does not work for folders with period in the filename example: "Folder.Example"
well i will see about the period thing
and about the compression
i'm using the original Mszip compression i can change it to
LZX it is a higher one and supported by makecab
but don't know if it would work with the windows
but i will see what see for problem one then repost a new version with LZX
Maybe for the folder names with periods you could maybe try to add a backslash "\" example:
C:\Path.To.Folder
Change to
C:\Path.To.Folder\
nah it was another problem
i was using a function to split file name from a path but it was designed for files
so when used with folder have a "."
it gets it half name
i finished it and will post the new version after 10-15 min
Edit: Updated to 2.1
all issue pointed should be fixed
I tried v2.1, hoping to cab a svcpack addon but only entries.ini get cabbed. Svcpack sub-folder was ignored. Can v2.1 work with subfolder?
sadly no
it only works with files not subfolder
i'm still trying to find a way
but until now makecab doesn't support it
hope that i find a workaround soon
great little tool
a couple of things:
change from LZX:18 to LZX:21
spelling error: change combressing to compressing
Updated and made the Compression memory as you requested
and fixed the spelling
Now were talking!!! thanks for the tool DM
no problem Rick i'm glad you like it
i also got some great news for every one
subfolder would be supported in V3 :thumbsup_anim: :thumbsup_anim:
but it would be dam hard for me to make it but i will do my best in doing it
i found the way using makcab but it would be in a while
as i would rewrite some functions in the tool to fully support that
that all i can say
peace :D
k Guys i have some good news
sitting for 3 hours and typing commands seems to do the job
i finished the sub folder commands
i was amazed that it actually worked << a lot of testing
now it seems ready but calling it V3 for only support sub dir and also mark on files and folder and it would cab
but i want also to add something and sadly i ran of ideas
so if anyone got an interesting idea i will be happy to do it (if it's possible)
so what do you say should i upload the V3 with only sub folder support or what ?
Modifype files while cabbing them?
i.e. "Modifype file.ext -c"
hmm your idea gave me an idea
ok first i didn't want to add another feature like modifype (as it's not connected)
but then i got hit by somethings
so in the Send To it's default with the same only compressing files
i may add in the context menu something like
Cab Files with Option
you can choose the compress Type , Name of the file , Modify Pe and the output name
i will be out for colleague now when i'm back i will see if this was possible
so i want what you think guys first?
also one question
did modifype work with 7 i remember it was not working ??
As long as it can cab a svcpack folder properly, I'm happy + output.cab filename should not be always in UPPERCASE. (that is something I find annoying in cabtool.exe :)) Preferably the output cab name follows the same folder name that I'm cabbing. I dun know if that is possible ... but that is my preference... not necessary have to do it if there is constraint. Thanks
well my tool doesn't change the name
it does it the same as the folder name
not changing any thing
i created it that way and not planning to change it
the only thing i might change is that cabbing
a multi files the output would be the folder name
not the first file entered to the tool
Updated to V3.0
ok i didn't have time to make the following tasks
they would be in V3.1
Right Click Add to Cab Archive (choose cab compress type , file name and Kels Request for ModifyPe)
making the multi files by folder name not a file name
PEChecksum by n7Epilson works on Vista/Windows 7, modifyPE doesnt
And congrats on the program its working perfect...CAB compression is just as small as TugZIP
yeah i needed to be sure that modifype not working i know about PEChecksum
the reason i didn't wait to add PEChecksum or modifyPe support yet
is that making modify pe for all files
would be a bad idea in my opinion
so i'm just laying my head down until i can get a close idea for the PE
thinking of making it available only for compressing one file
but still maybe a pick files option (but that would be hard)
so it maybe a few days until i got the best idea of them and see if it's possible
and thx for your post :blush:
