Dumpy Dooby Posted September 30, 2009 Posted September 30, 2009 (edited) ie7pro 2.4.7IE7Pro_2.4.7_DumpyDoobyAddons_20090930.zip - 2.44 MBMD5: 8ba6b66872679b4428a04dbfa891ba24Installs To: %PROGRAMFILES%\Internet\IEProShortcut: noneLast Updated: 20090930Notes: The following changes have been made:Uninstaller has been removed. Personally, I like to keep ARP clean of debris. I don't really see anyone removing this program entirely. It takes up all of 3 MB and it can be disabled. At the moment, I don't intend to make an uninstaller for it. Some settings are placed in the default profile's "Application Data" directory.License: FreewareDescription: IE7Pro is a must have add-on for Internet Explorer, which includes a lot of features and tweaks to make your IE friendlier, more useful, secure and customizable. IE7Pro includes Tabbed Browsing Management, Spell Check, Inline Search, Super Drag Drop, Crash Recovery, Proxy Switcher, Mouse Gesture, Tab History Browser, Web Accelerator, User Agent Switcher, Webpage Capturer, AD Blocker, Flash Block, Greasemonkey like User Scripts platform, User Plug-ins, MiniDM, Google sponsored search,IE Faster and many more power packed features. You can customize not just Internet Explorer, but even your favorite website according to your need and taste using IE7Pro.Features: Enhance Internet Explorer's Tabbed Browsing CapabilitiesDouble click to close tab.Open new tab from address bar.Enable/disable tab browse history manager.Enable/disable crash recoveryMove the IE menu bar above the address barHide search bar.Modify the maxium number of parallel connections to the web server.Select the external program to view page source[*]Super Drag and DropWith Super Drag and Drop enabled, you can open new links by simply dragging and dropping the link on the page. You can also Drag and Drop to search selected words with the default search engine or save the selected photo when Shift is held down.Mouse GestureMouse Gesture allow the user to execute commonly performed tasks (open/close a tab, go back, go forward , print , scrolling page etc.) by drawing a simple symbol on the screen.[*]Crash RecoveryCrash Recovery automatically restores all opened pages after a crash happened.Save Page to ImageFlexible and easy-to-use tool that converts html page from any URL to image. It captures the whole web page's content into JPG, BMP , GIF , PNG or TIFF on the fly.[*]Quick Proxy SwitcherDifferent internet connections do often require completely different proxy server settings and it's a real pain to change them manually.AD BlockerBlocks all forms of advertising, including Flash ads, rich media, fly-ins, slide-ins, pop-ups, pop-unders, spyware and adware ads, and messenger ads.[*]Greasy monkey alike User ScriptIE7Pro Script is to Internet Explorer7 as Greasemonkey is to Firefox. It lets you remix the Web via scripts.Inline SearchAdds the inline search bar like firefox has, finds as you type, use the F3 and Enter Key to cycle between multiple results, highlight all results.[*]Spell CheckIE7Pro Spell Check will check any text you enter and alert you to possible errors by adding a red underline to any potentially misspelled words.Grab&DragGrab & Drag mode permits you to "grab" the web page and move it within the pane by clicking and dragging the page. Edited October 1, 2009 by Dumpy Dooby Quote
mestresan Posted February 21, 2010 Posted February 21, 2010 (edited) I am trying install ie7pro in "silent" with nlite but dont install.On nlite, I install IE8 first, after put Ie7pro addon, but dont work ..Why ?If I install after full install windows in normal mode, works :S... Edited February 21, 2010 by mestresan Quote
ed2000 Posted March 22, 2010 Posted March 22, 2010 when you get time sir could you update this addon to IE7Pro 2.4.8 thank you Quote
