These tweaks and fixes are not my work. I picked it up from various sites.
Use the tweaks at your own risk.
Credits goes to their original authors.
The oldest advice is still the best advice:
Back up the registry and have a valid restore point before editing the registry
; XP Tweaks Collection.
; This file is segmented into these sections:
; - General Settings
; - General Customation
; - Startup / Shutdown
; - Logon
; - Start Menu
; - Context Menus
; - Multim
Edited by N1K
Remove print from all the files:
Remove "Print" option from the context menu for image & text files [-HKEY_CLASSES_ROOT\SystemFileAssociations\image\shell\print][-HKEY_CLASSES_ROOT\SystemFileAssociations\text\shell\print]-----------------------------------------------------------------; Remove Print From Images[-HKEY_CLASSES_ROOT\SystemFileAssociations\image\shell\print][-HKEY_CLASSES_ROOT\SystemFileAssociations\text\shell\print];-----------------------------------------------------------------------------------------; Remove Print From TXT Files[-HKEY_CLASSES_ROOT\txtfile\shell\print];-----------------------------------------------------------------------------------------; Remove Print From REG Files[-HKEY_CLASSES_ROOT\regfile\shell\print];-----------------------------------------------------------------------------------------; Remove Print From CMD Files[-HKEY_CLASSES_ROOT\cmdfile\shell\print];-----------------------------------------------------------------------------------------; Remove Print From Batch Files[-HKEY_CLASSES_ROOT\batfile\shell\print];-----------------------------------------------------------------------------------------; Remove Print From INI Files[-HKEY_CLASSES_ROOT\inifile\shell\print];-----------------------------------------------------------------------------------------; Remove Print From INF Files[-HKEY_CLASSES_ROOT\inffile\shell\print];-----------------------------------------------------------------------------------------; Remove Print From PHP Files (Change AppName, To Name Of Default App For File Type)[-HKEY_CLASSES_ROOT\AppName.php\shell\print];-----------------------------------------------------------------------------------------; Remove Print From PDF Files (Change AppName, To Name Of Default App For File Type)[-HKEY_CLASSES_ROOT\AppName.Document\shell\print];-----------------------------------------------------------------------------------------; Remove Print From Word Docs[-HKEY_CLASSES_ROOT\Word.Document.8\shell\Print];-----------------------------------------------------------------------------------------; Remove Print From PowerPoint Docs[-HKEY_CLASSES_ROOT\PowerPoint.Show.8\shell\Print;-----------------------------------------------------------------------------------------
with
[HKEY_CLASSES_ROOT\Directory\shell\Command Prompt Here]@="Command Prompt Here"[HKEY_CLASSES_ROOT\Directory\shell\Command Prompt Here\command]@="cmd.exe /k cd %1"
What is the @ symbol mean? Because in HKEY_CLASSES_ROOT\Directory\shell\ there is only \find\.
  • 10 months later...
  • 8 months later...
for faster boot
;Allows boot files to be placed optimally on the hard-drive for faster boots.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Dfrg\BootOptimizeFunction]"Enable"="Y";Disables Backup System Files with Successful Boot[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]"ReportBootOk"="0"
no my documents/shared folder etc in my computer (vista style my computer)
Windows Registry Editor Version 5.00 ;Remove Shared Documents from My Computer[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\MyComputer\NameSpace\DelegateFolders\{59031a47-3f72-44a7-89c5-5595fe6b30ee}]
rename my documents and my computer to like of vista
Windows Registry Editor Version 5.00; Rename My Computer,Documents,network plces etc to like of Vista[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID\{20D04FE0-3AEA-1069-A2D8-08002B30309D}]@="Computer"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID\{450D8FBA-AD25-11D0-98A8-0800361B1103}]@="Documents"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CLSID\{208D2C60-3AEA-1069-A2D7-08002B30309D}]@="Network Places"
general system performance boost up
Windows Registry Editor Version 5.00; Speed up Opening of My Computer and Windows Explorer[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced]"NoNetCrawling"=dword:00000001[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer]"NoRemoteRecursiveEvents"=dword:00000001; Speed up Copying/Moving of .ZIP Files[-HKEY_CLASSES_ROOT\.zip\CompressedFolder][-HKEY_CLASSES_ROOT\CLSID\{E88DCCE0-B7B3-11d1-A9F0-00AA0060FA31}][-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CompressedFolder]; Speed up Shutdown[HKEY_CURRENT_USER\Control Panel\Desktop]"AutoEndTasks"="1""HungAppTimeout"="100""WaitToKillAppTimeout"="1000"[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control]"WaitToKillServiceTimeout"="1000"; Speed up Access to .AVI Media Files[-HKEY_CLASSES_ROOT\CLSID\{87D62D94-71B3-4b9a-9489-5FE6850DC73E}]][-HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex\PropertyHandler][-HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87D62D94-71B3-4b9a-9489-5FE6850DC73E}\InProcServer32]; Optimize Core System Performance[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management]"DisablePagingExecutive"=dword:00000001
