Posted October 3, 200915 yr OK, I have tried everything but can't get my CPU to read 3.0G unless I am running a heavy load.Here is my BIOS Options.CPU ConfigurationGART Error Reporting [Disable/Enable]Micro Code Updating [Disable/Enable]Secure Virtual Mode [Disable/Enable]Cool N' Quite [Disable/Enable]CPU Prefetch [Disable/Enable]C1E Configuration [Disable/Enable]Advanced Clock Calibration [ Disable/Auto/All Core/Per Core] Unleashing Mode [Disable/Enable] Value [0%-12%/-2%--4%]JumperFree ConfigurationCPU Clock [Manual/Auto/OverClock Profile/Test Mode] CPU/HT Ref [200-550]GPU Overclocking [Manual/Auto] GPU Engine Clock [200-550]PCIE Overclocking [Auto/Manual] PCIE Clock [100-150]CPU RATIO and VOLTAGEProcessor Frequency Multiplier [Auto] or you can set voltageCPU Over Voltage [Auto] or you can set voltageVDDNB voltage [Auto] or you can set voltageHT Link Frequence [Auto/Manual] Manual Mode [200-2000]HT Link Width [Auto/8bit/16bit]HT Overclocking Voltage [Auto] or you can set voltageMEMORY TIMING and VOLTAGEMemory Clock Mode [Auto/Manual] Memory Clock Value [200-533]DRAM Timing [Auto/DCT0/DCT1/Both]Memory Over Voltage [Auto] or you can set voltageCHIPSET VOLTAGEChipset Over Voltage [Auto] or you can set voltageI can use some suggestions on what the settings should be set at.THANKS Edited October 3, 200915 yr by LUZR4LIFE
October 3, 200915 yr I have my quad core q6600 @ 2.66 Ghz for 2 years now. Never had feel the need to overclock it Don't burn it before you start using it
October 3, 200915 yr Author I have my quad core q6600 @ 2.66 Ghz for 2 years now. Never had feel the need to overclock it Don't burn it before you start using it My CPU-z CPU Speed is at 798.3mb. Isn't there away to get that to 3.0G? It's a 3.0 CPU.
October 3, 200915 yr My CPU-z CPU Speed is at 798.3mb. Isn't there away to get that to 3.0G? It's a 3.0 CPU.well maybe it's just cooling it down so no need to use it full speed like only when you play you will use that hole power but in the normal way it won't it's like smart fan works only when the heat is high
October 3, 200915 yr OK, I have tried everything but can't get my CPU to read 3.0G unless I am running a heavy load.Cool N' Quite [Disable/Enable]thats the reason. cool n'q automatically downclocks your processor when it is not being used. then when under heavy load it ramps up the speed. i would not recommend you disable it because why waste all that electricity if you are not using it? also it keeps your computer cooler and your room as well all processors from the last 3 or 4 years have this implementation. intel does as well, but i forget what they call theirs. i think intel even shuts off some of their cores when not in use.. or maybe that is just in their laptop processors
October 3, 200915 yr Yes, my ASUS board also has an EPU chip which saves power by downlclocking my processor once the full power isn't needed.
October 3, 200915 yr Author You are the man ccl0. Now it's running at 2.993ghz. It is so much faster now.
October 3, 200915 yr Yes, ccl0 is right indeed. Cool and Quiet saves energy, but clocks down your CPU. A lot.
October 4, 200915 yr Yes, ccl0 is right indeed. Cool and Quiet saves energy, but clocks down your CPU. A lot. i'm perplexed by that comment, because you make it seem like that is a bad thing. but it does not stay like that all the time. it downclocks the cpu when it is not needed. think about all those people who leave their computers on overnight. all that power being wasted just sitting idle
October 4, 200915 yr Author i'm perplexed by that comment, because you make it seem like that is a bad thing. but it does not stay like that all the time. it downclocks the cpu when it is not needed. think about all those people who leave their computers on overnight. all that power being wasted just sitting idleI noticed how slow it was running, that's why I wanted it off. It would be cool if there was away to activate it when you are going to be away from your PC for awhile to save on energy.
October 4, 200915 yr Thanks I did not know what exactly cool n quiet did until now...I thought it had to do with the fan speed, fast when its hot and slow when its cooler
