CRC32 : 988DCEF8
MD4 : 918BFA83CEFD569369A31D06A9A887D9
MD5 : 6E7D27015B4EE59F88960A0B97772E0C
SHA-1 : 8E8BEFEEEA664DA2B159621EA1B6563C5729D3D8
Publisher : EASEUS
License : FREE
Version : 9.1.1
System : 2000/XP
Language(s) : English
EASEUS Partition Master Home (formerly EASEUS Partition Manager) is a comprehensive partition software, which not only provides with convenient user-interface simplifying your tasks but also enables you to perform basic and advanced partition operations on server and non-server systems without data loss.
EASEUS Partition Manager Home Edition is an excellent free Partition Magic alternative (it has overtaken Partition Magic for a big step.)
FEATURES
You can create, delete, format, copy and clone partitions on your hard disk quickly and easily.
The most attractive feature is that it can resize/move your partitions by using the free spaces without destroying data. Disk & Partition Clone supported now.
This addon is installable/uninstallable by Add/Remove Windows components Windows
Edited by Ken@fri
Updated.
Links location modified :
from : %ALLUSERSPROFILE%\Start Menu\Programs\EASEUS Partition Master 4.0 Home Edition
  Quote
[epm.Deskcut]
Name ="Partition Master 4.0 Home Edition",8,25
CmdLine =16422,"%EPM_PATH%\bin",epm0.exe
WorkingDir=16422,"%EPM_PATH%\bin"
InfoTip ="Run EASEUS Partition Master"
[epm.Startcut]
Name ="Partition Master 4.0 Home Edition",8,23
SubDir =%DISPLAYNAME%
[epm.Help.StartCut]
Name ="Partition Master - Help",8,23
CmdLine =16422,"%EPM_PATH%\bin",Help.exe
WorkingDir=16422,"%EPM_PATH%\res"
IconPath =16422,"%EPM_PATH%\res",help-icon16.ico
InfoTip ="Guide you to use EASEUS Partition Master"
[epm.pdfHelp.StartCut]
Name ="Partition Master - Help PDF",8,23
CmdLine =16422,"%EPM_PATH%\bin",EPM.pdf
WorkingDir=16440,Xtr3mRES_Lib
IconPath =16440,Xtr3mRES_Lib,PartMasteRes.dll
IconIndex =3
InfoTip ="Instruct EASEUS Partition Master"
TO : %USERPROFILE%\Start Menu\Programs\EASEUS Partition Master 4.1 Home Edition
  Quote
[epm.Deskcut]
Name ="Partition Master %New_Vers% Home Edition",8,16
[epm.Startcut]
Name ="Partition Master %New_Vers% Home Edition",8,2
[epm.Help.StartCut]
IconIndex =3
Edited by Ken@fri
INF file typo error fixed (MD5 checksum too)
from
  Quote
[stop.epm]
11,,tskill.exe,,,"Help.exe"
to
  Quote
[stop.epm]
11,,tskill.exe,,,"Help"
Sorry :blush:
  • 4 weeks later...
Added command "TSKILL Help" to section [Close.EPM]:
Before
  Quote
[Close.EPM]
TSKILL epm0
%11%\setupempdrv03.exe -Uninstall
After
  Quote
[Close.EPM]
TSKILL Help
TSKILL epm0
Sorry :blush:
  • 4 weeks later...
Hi !
CHANGELOG :
* Rebuilding addon. Now, all my addons have a single main entry in Add/Remove Windows Components
* Added Xtr3mres.inf file : it lists all catogories/sub-categories of my addons
(templates : Accessor.inf + Games.inf located in %windir% \inf in live XP | in I386 dir on your XP CD/DVD.)
A SPECIAL BIG HUGE THANX to ENU_user
* Added an uninstall link in Partition Master startmenu dir (StartMenu\EASEUS Partition Master 4.1 Home Edition)
* Change resources file name (new name --> Xtr3mAddOnRes.dll) & its location (new dir --> %SystemRoot%\Resources\Xtr3mAddOneRes)
* Using of a Desktop.ini file to customize resources Dir
Edited by Ken@fri
  • 4 months later...
- Updated
  • v6.1.1
  • Xtr3mAddOneRes.dll (v1.0.0.17)
- Added:
  • support for
    - Uninstalltion of three (03) EPM original releases (both previous & the last one)
    - Uninstalltion of my addons releases (both previous & the last one)
  • Commands (below)
    -TSKILL main to [Close.EPM] section
    -11,,tskill.exe,,,"main" to [stop.epm] section
- Updated (v6.5.1)
- Xtr3mAddOneRes.dll updated (v1.0.0.18)
- Added:
  • support for
    - Uninstalltion of four (04) EPM original releases (three previous [v5.8.1, v6.0.1, v6.1.1] & the last one [v6.5.1])
    - Uninstalltion of my addons releases (three previous & the last one)
Add fix about files (system32) names (see 1rst post).
[epm.sys32]
BootMan.exe,pmstr520.exe
epmntdrv.sys,pmstr521.sys
EuEpmGdi.dll,pmstr522.dll
EuGdiDrv.sys,pmstr523.sys
setupempdrv03.exe,pmstr524.exe
[sourceDisksFiles]
pmstr715.exe = 1
pmstr716.sys = 1
pmstr717.dll = 1
pmstr718.sys = 1
pmstr719.exe = 1
Sorry :sweatingbullets:
Edited by Ken@fri
  • 3 months later...
  • 7 months later...
