Posted (edited)
CDBurnerXP is a free application to burn CDs and DVDs, including Blu-Ray and HD-DVDs. It also includes the feature to burn and create ISOs, as well as a multilanguage interface. Everyone, even companies, can use it for free. It does not include adware or similar malicious components.
Key Features
  • burn all kinds of discs
  • audio-CDs with or without gaps between tracks
  • burn and create ISO files
  • data verification after burning process
  • create bootable discs
  • multi-language interface
  • bin/nrg & 8594
  • ISO converter, simple cover printing and much more!
FILE ASSOCIATION :
  • .axp (CDBurnerXP Audio Compilation)
  • .dxp (CDBurnerXP Data Compilation)
PREREQUISITES : .NET Framework 2.0 / .DirectX 8
This addon is installable/uninstallable by Add/Remove Windows Components function.
Publisher : Canneverbe Limited
License : Free
Version : 4.2.6.1706
System : 2000 / XP /2003 Server /Vista /Windows 7
Language(s) : Englishs/French
R E M O V E D
Changelog
08.10.2009
Update to v4.2.6.1706
07.10.2009
(silent) Update to v4.2.5.1541
14.05.2009
CDBrnrXP.inf minors modifications
08.05.2009
Release (v4.2.4.1351)
Edited by Ken@fri
When trying to burn audiofiles the app. warns that the feature is corrupted and the application closes. Uninstalling also doesn't work. You have to run the classical installer over it to get it working (and uninstalling)
Hi jaynbe !
Thanx 4 u'r report.
I've download this addon again from link pointing here. After tests, my CDBurnerXP addon uninstaller works perfectly.
But you're right about audiofiles burning problem :confused02: . Then, I remove it until fixing :thumbsdown_anim: .
EDIT : CDBUrnerXP v.4.2.6.1748 is out.
Addon updated & fixed will be available in few days.
:blush:
