xjch18 Posted February 15, 2007 Posted February 15, 2007 ok here's what happened.. i wanted to delete a partition and it my laptop was stuck.. so i had to reboot. when i reboot the other partition was not recognised! it says other..and the files in that partition was deleted. i dunno what happened.. but thats not the problem. it's ok now i just deleted the partition..the problem is, i have an external cd-rom, a usb cd-rom.. now, when i had the 1st problem above i got this 2nd problem.. my cd-rom is not in my computer.. you know, like the other hard drives.. when you open my computer and you will see your local disk, cd-rom drive.. my cd-rom drive was not there! although when i opened the device manager, the cd-rom was there.. it says DVD/CD-RW.. but it's not in my computer..what is the problem? and also, when i insert a disk, it doesnt start the setup.. because i want to install something.. does it have to do with the changes in the drive letters thats why it doesnt put any drive letter in my computer? grrr! i was so upset now.. if someone can help please help... Quote
NIM Posted February 15, 2007 Posted February 15, 2007 Can you check the status of the disks, including CD-ROM in Disk Management and post it here? Quote
monkey56657 Posted February 18, 2007 Posted February 18, 2007 (edited) In disk management right click on the disc drive and click change driver letter/path. Set a letter. May need to restart....Computer Central Support Team Edited February 18, 2007 by monkey56657 Quote
