Entries.ini - copy files [HELP]
fred_gaou
Hi,
I use nlite and I want to create an addon that installs Devcon.exe (simply copy the files in system32, indeed) in my XP SP3. Can I do that only using the entries.ini files or must I add an inf files?
Here is the addon structure I'd like to:
Devcon.cab
+DEVCON.EX_
+ENTRIES_devcon.INI
ENTRIES_devcon.INI content:
[general]
builddate=2009/10/11
description=utilitaire de ligne de commande qui peut
Link to comment
Share on other sites
just replace 100 with 1
[txtsetup_files]
DEVCON.EXE = 1,,,,,,,2,0,0
that if you would put your file compressed with cab
if not before the 2
add _x
if you want more info
see this link
Edit:
you seem that you compressed it
so it should work with no problem
Edited by DaRk MaDnEsS
Link to comment
You can use either 1 or 100 does not matter for XP (use 1 if you want it to be compatible with win2k)
Your entries.ini code is fine, I have no idea why its not working it looks ok to me
And no you do not have to add .inf files for this
Thanks.
I didn't say it's not working because I haven't tested yet. ;)
Edited by fred_gaou
Link to comment
As for the number for the folder location you can find that in TXTSETUP.SIF
[WinntDirectories]
1 = "\"
2 = system32
3 = system32\config
4 = system32\drivers
5 = system
7 = system32\ras
9 = system32\spool
10 = system32\spool\drivers
11 = system32\spool\drivers\w32x86\3
12 = system32\spool\prtprocs
13 = system32\spool\prtprocs\w32x86
14 = system32\wins
15 = system32\dhcp
16 = repair
17 = system32\drivers\etc
18 = system32\spool\drivers\w32x86
19 = system32\drivers\disdn
20 = inf
21 = Help
22 = Fonts
23 = Config
24 = msagent\intl
25 = Cursors
26 = Media
27 = java
28 = java\classes
29 = java\trustlib
30 = system32\ShellExt
31 = Web
32 = system32\Setup
33 = Web\printers
34 = system32\spool\drivers\color
35 = system32\wbem
36 = system32\wbem\Repository
37 = addins
38 = "Connection Wizard"
39 = "Driver Cache\i386"
40 = security
41 = security\templates
42 = system32\npp
43 = system32\ias
44 = system32\dllcache
45 = Temp
46 = Web\printers\images
47 = system32\export
48 = system32\wbem\mof\good
49 = system32\wbem\mof\bad
50 = twain_32
51 = msapps\msinfo
52 = msagent
53 = msagent\chars
54 = security\logs
55 = system32\icsxml
57 = system32\mui
58 = %MUI_PRIMARY_LANG_ID_DIR%
59 = system32\mui\dispspec
60 = AppPatch
61 = Debug
62 = Debug\UserMode
63 = system32\oobe
67 = Help\Tours
68 = Resources\Themes\Luna
69 = Resources\Themes\Luna\Shell\NormalColor
70 = system32\oobe\html\ispsgnup
71 = system32\oobe\html\mouse
72 = system32\oobe\html\oemcust
73 = system32\oobe\html\oemhw
74 = system32\oobe\html\oemreg
75 = system32\oobe\images
76 = system32\oobe\setup
77 = system32\oobe\sample
78 = Resources\Themes\Luna\Shell\Metallic
79 = Resources\Themes\Luna\Shell\Homestead
91 = Help\Tours\mmTour
92 = Help\Tours\htmlTour
93 = Provisioning\Schemas
100 = system32\1025
101 = system32\1028
102 = system32\1031
103 = system32\1033
104 = system32\1037
105 = system32\1041
106 = system32\1042
107 = system32\1054
108 = system32\2052
109 = system32\3076
110 = system32\wbem\xml
111 = system32\usmt
112 = system32\inetsrv
123 = mui
124 = WinSxS
125 = WinSxS\Manifests
126 = WinSxS\InstallTemp
127 = ime
129 = Resources\Themes
130 = ime
132 = ime\imejp
133 = System32\IME\PINTLGNT
134 = System32\IME\CINTLGNT
135 = System32\IME\TINTLGNT
136 = IME\CHTIME\Applets
137 = ime\imejp98
138 = ime\imejp\applets
139 = pchealth\helpctr\binaries
180 = system32\3com_dmi
181 = PeerNet
239 = system32\wbem\Logs
240 = ehome
241 = "Network Diagnostic"
242 = L2Schemas
Link to comment
