Posted October 15, 200915 yr This is a long shot BUT here goes.I have made a x86 and x64 a-i-o disk with a couple extras, however it is getting a hair too big.What are things I can MANUALLY remove from the disk?Also if possible is there anything I can remove from the wim to save space?Please remember this needs to be a full disk without any things removed (EXCEPT maybe the upgrade option)
October 15, 200915 yr I started on the manual dism removal for windows 7 but quickly stopped because it broke allot of things, this is all I remove (I also manually remove the sample vids from the public folder)for %i in (LocalPack-AU LocalPack-CA LocalPack-GB LocalPack-US LocalPack-ZA) do dism /image:c:\mount\ /Remove-Package /PackageName:Microsoft-Windows-%i-Package~31bf3856ad364e35~x86~~6.1.7600.16385But if you want to unhide the stuff you can remove you can use a tool called install_wim_tweak.exe, this way you can remove a whole lot of stuff...here is what I used to remove from 7 ultimate (but I strongly discourage it from being used)install_wim_tweak /p c:\mount\ /mfor %i in (Anytime-Upgrade-ResultsBackupBLB-ClientClient-Wired-Network-DriversClipsInTheLibraryCommon-Modem-DriversIIS-WebServer-AddOn-2IIS-WebServer-AddOnIIS-WebServerIndexing-ServiceLocalPack-AULocalPack-CALocalPack-GBLocalPack-USLocalPack-ZANFS-ClientSKUOfflineFilesOpticalMediaDiscParentalControlsPeerToPeer-FullPrinter-DriversRasCMAKRasRipRemoteAssistanceSampleContent-MusicSampleContent-RingtonesShell-HomeGroupShell-MultiplayerInboxGamesShell-PremiumInboxGamesShell-InboxGamesShell-SoundThemesSnippingToolSNMPStickyNotesSUASystemRestoreTabletPC-OCTelnet-ClientTelnet-ServerTFTP-ClientTuner-DriversWinOcr) do dism /image:c:\mount\ /Remove-Package /PackageName:Microsoft-Windows-%i-Package~31bf3856ad364e35~x86~~6.1.7600.16385The vLite section have allot of guides like this one that may help
