Posted October 15, 200915 yr When i try to download some of the things from this else excellent toolkit you have make, i get this error message .. Even if i was choosing to download to "root" with a foldre called lets say "C:\w7" -- Because first i thought i was because of the length of the folders/file if it was in like "C:\Documents and Settings\my name\Downloads\filname.here" because it was usually when it was long names, at least i thought , bought it does it also when i queue lest say 10 downloads with small file names, like 7-zip, hashtab etc you have linked toSe slutningen af denne meddelelse, hvis du vil have detaljer om,hvordan du starter JIT-fejlfinding i stedet for denne dialogboks.************** Undtagelsestekst **************System.ArgumentOutOfRangeException: startIndex kan ikke verror_toolkit.txt
October 22, 200915 yr Author What version are you using?seSorry about the lack of answer .. But I have been on work .. The version i use is 0.2.x you have in topic, and it automatic update for 0.5.x Alpha something. -
