[Addon] inSSIDer v1.2.2
[Addon] inSSIDer v1.2.2 (INT)
inSSIDer is an award-winning free Wi-Fi network scanner for Windows Vista and Windows XP. Because NetStumbler doesn't work well with Vista and 64-bit XP, we built an open-source Wi-Fi network scanner designed for the current generation of Windows operating systems. inSSIDer was discussed by Lifehacker and Tekzilla!
What's Unique about inSSIDer?
* Use Windows Vista and Windows XP 64-bit.
* Uses the Native Wi-Fi API.
* Group by Mac Address, SSID, Channel, RSSI and "Time Last Seen."
* Compatible with most GPS devices (NMEA v2.3 and higher).
How can inSSIDer help me?
* Inspect your WLAN and surrounding networks to troubleshoot competing access points.
* Track the strength of received signal in dBm over time.
* Filter access points in an easy to use format.
* Highlight access points for areas with high Wi-Fi concentration.
* Export Wi-Fi and GPS data to a KML file to view in Google Earth.
Platform: Windows XP/SP2 with .Net v2.0, Vista & Win 7 (x86 & x64)
Author: MetaGeek, LLC
License: Apache License v2.0
Website: http://www.metageek.net/products/inssider
About this release:
- As requested by newsposter.
- Uses the original inSSIDer MSI.
- This application requires .Net Framework v2.0 (or higher)!
- 7-Zip SVCPACK Addon (for switchless installer, just extract it from the archive).
7-Zip SFX Code:
;!@Install@!UTF-8!
GUIMode="2"
RunProgram="Inssider.msi /qb"
;!@InstallEnd@!
Addon Details (RVMi and nLite compatible):
File: beats_inSSIDer_1.2.2_INT_Addon.7z
CRC-32: 02187f0c
MD4: db16f62aec1a6f79634da98cae8ddfa3
MD5: e97e8d9418079d4ff9f5c9f037c1f9a6
SHA-1: 689a66305745053b750144f1fceca858f0857974
Download
