[SVCPACK] Addon GD WinTools.Net Ultimate 9.10.1.0
Posted (edited)
[sVCPACK] Addon GD WinTools.Net Ultimate 9.10.1.0.cab
This app turn on full version after you apply your own Serial
I particularly think CCLeaner is very elementary and incomplete. System Mechanic, unnecessarily complicated and dangerous. And many others...
WinTools.net, jointly with Tuneup Utilities, I believe that is what there is of better.
But WinTools.net is a tool just for advanced users. Be careful.
Well...I like those tools of precision a lot and then I decided to post Wintools for all you. :)
WinTools.net cleanly removes unwanted software from disk drives and dead references from the Windows registry. Ensures your privacy and keep sensitive information secure.
WinTools.net puts you in control of the Windows start up process, memory monitoring and gives you the power to customize desktop and system settings to fit your needs.
Contains tools:
Clean UninstallerWinTools.net: Clean Uninstaller
Used for both correctly removing software and for monitoring changes made to the hard drive, MS Windows registry and system files during program installations.
Scan FilesWinTools.net: Scan Files (here, be careful)
Used for periodic cleaning of your hard drive from dead references, junk and obsolete files produced by different software.
These files and references remain on the hard disk and increase drive access time.
Scan ShortcutsWinTools.net: Scan Shortcuts
Used for periodic cleaning of your Desktop, Start-menu, Application data and hard drives from dead shortcuts, These shortcuts remain on the hard disk and increase drive access time.
Scan RegistryWinTools.net: Scan Registry (here, be careful)
Used for periodic cleaning of the MS Windows registry from unused applications remaining after uninstallation and from invalid references which decrease system speed and system loading time.
Startup ManagerWinTools.net: Startup Manager
This tool allows you to monitor, add, remove, enable and/or disable individual startup items. You can also adjust applications initialized during the loading process of the operating system.
Tweak UIWinTools.net: Powerful Tweaks
This is a set of additional adjustments related to safety, system capacity and user preferences and which are not included in the basic components of MS Windows.
Net TweakerWinTools.net: Net Tweaker
The tool is used for speed increasing of data transfer and for greater stability of connection by changing hidden network settings. Available only in "Professional" edition.
The PrivacyWinTools.net: Your Privacy
This is a kit of tools which ensure your privacy and keep sensitive information secure.
Invisible ManWinTools.net: Invisible Man (here, be careful)
This tool is used for saving private information and its later restoration. This is useful if you don't want any information saved by the system.
File ShredderWinTools.net: File Shredder
This tool is used for full secure deleting documents, programs, and any other files without possibility to restore them.
RAM Memory BoosterWinTools.net: RAM Memory Booster
This tool serves for monitoring, cleaning and optimisation of RAM. It is used for increasing of operating system performance and for releasing RAM for usage by other processes.
For Operating Systems: Windows 7 - Vista - XP - 2k - 2k3 - 2k8 --> (x86) (x64) - Multilanguage.
Homepage: http://www.wintools.net/
Download: http://www.4shared.com/file/141631934/eb77e3e0/Addon_GD_WinToolsNet_Ultimate_91010Multilanguage.html
MD5: AEE8A4B0EAFF53018F2D1DC7D6898651
All my Addons: http://www.4shared.com/account/dir/16857257/76ffa519/sharing.html
Edited by arsenalz
