Posted February 17, 200718 yr I knew that I can use flip 3D in vista, but how to do this?Video: vista3d
February 18, 200718 yr I'm not certain, but could that be part of DreamScene or w/e they call it?I'd still be interested in knowing
February 18, 200718 yr Find windows, fast. TopDesk is a quick and easy way to switch between applications. With a single key press, you can instantly view thumbnails of all open windows, display thumbnails of windows belonging to the current application, or hide all windows to quickly access the desktop. http://www.otakusoftware.com/topdesk/
February 18, 200718 yr Author Yeah, but this is for WinXP and we're discussing Vista here. You can open a new thread in the Software Field, and provide a thumbnail of that app, along with this useful info..
February 20, 200718 yr i think were thinking too much inside the box on this onenote: he does not ONCE enter normal Flip3d mode before the windows become curvednote: the WHOLE windows becomes translucent, not just the glass, this doesn't happen in Flip3d
February 28, 200718 yr http://dream.wincustomize.com/index.aspx?c=1I think this is actually what the guy was using, maybe. I don't know if it works with Vista.edit: Apparently, it's Vista-only. There ya go Edited February 28, 200718 yr by beemarin
March 5, 200718 yr http://dream.wincustomize.com/index.aspx?c=1I think this is actually what the guy was using, maybe. I don't know if it works with Vista.edit: Apparently, it's Vista-only. There ya go That piece of software is ONLY for Vista Ultimate WITH DreamScene. I've juste download it because it's free but I didn't test it yet. As far as I know this is just for animated backgrounds, not for flip3D N1K mentioned . Although, DreamScene takes a lot of resources and offers very little (if you have animated scene that is not adjusted for looping you could have your nerves pop out cause you will see blink every time scene starts from begining :wacko: ). I hope that Dream is not so resource consuming even if it depends on DreamScene.
March 9, 200718 yr So here in update on DreamScape :w00t: . Just install it and it works like a charm. Even if it depends on DreamScene it is not so consuming like DreamScene. Defender was scaning my system with DreamScape enabled and max cpu load was 35%. When it was done scanning it was from 0-5% . With DreamScene desktop (without any other programs running) it never fell below 30% :wacko: .Well I just tried one scene (the one that came with instalation) but I imagine that this is some improvement over DreamScene. Is there any luck finding that flip3D that N1K posted in the first post :crying_anim02: ?Regards.
