Posted October 21, 200915 yr Kaufman Tray Launcher v 1.10Shorcut launcher via system trayWebsiteThis is an application that sits in the tray and displays various pre-configured software shortcuts.You can use this application if you want to speed up your application start process, because it allows you to open your software more quickly.Note: 1) Auto Startup item2) Install to %programfiles\Kaufman TrayLauncher3) No ununinstaller. All files are standalone.4) You can replace your own shortcut setting (Launchers.ini is located in %programfiles\Kaufman TrayLauncher) via KaufmanTrayLauncher01SI.exe after you have configured it thru the program GUI.5) KaufmanTrayLauncher02Edit.exe is a launchers.ini self-editor (Autoit complied script). It modifiies your Drive letter to systemdrive letter. Support ?\windows & ?\Program files path only. (Useful in dual-boot system)6) Sample Launchers.ini is provided with different Drive letter. After installation, it should map to your system drive letter. KaufmanTrayLauncher.cabSize: 537.63 Kb (550,534 bytes)MD5: 0BB6A9C60C74BAA6EABD3DB48C380C79 Edited October 21, 200915 yr by Geej
