Posted October 22, 200915 yr I have a problem with my Graphics card, turning on the pc, fan noise, a noise like a buzz, to remove this noise and I turn the pc back on. my graphics is club3d nvidia 7950GT. they believe that is the noise?thank
October 22, 200915 yr Sorry zookey I haven't understood you properly.If your fan is buzzing, you can check if there's some other cable touching the fan, or your fan might be bad.You can also try to clean the fan and remove the dust from i for a start.
October 22, 200915 yr I would suggest taking the side panel off, turn the PC back on and when the noise starts, lightly push on the fan to see if the noise stops. You may have a loose part on your card and may need to find out what. You could also remove the card and place it back in to see if that helps. I have never came across this problem and it will be hard to figure out without actually seeing/hearing the issue.
October 22, 200915 yr On 10/22/2009 at 2:18 PM, N1K said: Sorry zookey I haven't understood you properly.If your fan is buzzing, you can check if there's some other cable touching the fan, or your fan might be bad.You can also try to clean the fan and remove the dust from i for a start.LOL. I didn't even think that it could be dirty. That could be a possibility.
October 22, 200915 yr With the side cover off, touch each fan in the center hub (NEVER the blades!) to stop them one by one until you find the noisy one.
October 24, 200915 yr Author well bad news, I removed the along with his entire graphic Blower, I managed to remove some noise but I could lean Up the fan shaft because this integrated whole, if you made maybe 3 in 1 oil harms the circuit that powers the fan as I clean it? can not be dismantled but there is some liquid or special cleaner that will not damage electronic circuits?alone and could blow air and that is not enough, thank
October 25, 200915 yr try this http://www.rolexreferencepage.com/articles/qtip.jpg+ this http://www.wholesale-direct-first-aid.com/ProdImages/M-313.gif
January 17, 201015 yr On 10/25/2009 at 8:31 AM, ccl0 said: try this http://www.rolexrefe...ticles/qtip.jpg+ this http://www.wholesale...mages/M-313.gifLMAO
January 17, 201015 yr Mineral oil will grease and will not short any circuits, they build PC's in aquariums submerged in it with no problems
