Posted October 23, 200915 yr i need some help i making custom xp cd..I have xp sp2 cd ( unmodified ) . i am thinking of integrating sp3 on it with ie8 & wmp11 and make a new cd .will this create any problem ? and till now i haven't made any bootable cd.. need help on this too.thanks.
October 23, 200915 yr well use nlite it should be easy you can find in it integrate service pack and hotfix (use any update pack ,user_hidden , one piece etc ..)and it can also make a bootable cd
October 23, 200915 yr I have a few XP version that I have made but the and the basic is a SP3, IE8 (OnePiece) and WMP 11 (Boooggy and n7Epsilon). I start all my XP builds after these integrations.
October 23, 200915 yr well i was working on a new XP cd for this month have been testing some stuff this month cd is like this Xp Sp3 + user_hidden update pack + yumeyao .NetFrame addon + yumeyao IE and WMP + onepiece .NetFrame 1.1 Addon+ my WLM Addon + my Microsoft Security essential addon (still under tests)i like it that way that how i start most of my xp cd (the difference is which addon should i use) Edited October 23, 200915 yr by DaRk MaDnEsS
October 23, 200915 yr + my Microsoft Security essential addon (still under tests)i was wondering the other day if someone was going to make an addon for that
October 23, 200915 yr i was wondering the other day if someone was going to make an addon for that well it's an easy addon only problem that after silent install it force it self to run and make update it only need a small shutdown and it's ready it seems that it's k to upload it but i need a couple of hours to sleep tomorrow it would be released
