Posted October 25, 200915 yr I need a silent graphics card For My Pc. Having low power consumption as I only Have 750 Watt Smps And i need some cheap DDR III memory 1600 Mhz of any Brand. Edited October 25, 200915 yr by Jatin Beniwal
October 25, 200915 yr Any card with a passive heatsink would be ideal. Anything above a HD4xxx series would run a bit hot. I have an HD3450 I use for DriverPacks testing and it runs fine. Newer cards have a built-in HDMI port which is ideal for HTPC builds.Are you looking to buy or asking for donations? Your OP is a little confusing.
October 25, 200915 yr Author Any card with a passive heatsink would be ideal. Anything above a HD4xxx series would run a bit hot. I have an HD3450 I use for DriverPacks testing and it runs fine. Newer cards have a built-in HDMI port which is ideal for HTPC builds.Are you looking to buy or asking for donations? Your OP is a little confusing.I m looking to buy within range of Rs.12000. Currently using Nvidia Geforce 8400GS produce too much sound that irritates me.
October 25, 200915 yr if you are happy with your card, a cheaper solution would be to get a third party vga cooler. they even make passive ones like this http://www.svc.com/fan-acces2.htmli've no idea if you can buy it where you are though. here are a few others you might be able to find in your area http://www.svc.com/vga-cooler.html
October 25, 200915 yr Oh, I just noticed you're from India. Ooh, it gets hot depending on your region. My favorite is Madras. Passive cooling won't be good enough if your ambient temp is high. Water cooling might be your best option. Using an external vented reservoir along with a massive radiator with slow moving fans would be an ideal option. The only problem is cost. A good kit will cost between USD$150-300 depending on the components. But will be damn near silent.
October 26, 200915 yr i'd say all 3rd party coolers would still be quieter than the stock cooler on the card he has and water cooling would be a tad overkill for an 8400GS Edited October 26, 200915 yr by ccl0
