Posted October 26, 200915 yr [Addon] LockHunter 1.0 Beta 3 ENU (x86 & x64)LockHunter is a foolproof file unlocker. It is a free tool to delete files blocked by something you do not know. LockHunter is useful for fighting against malware, and other programs that are blocking files without a reason. Unlike other similar tools it deletes files into the recycle bin so you may restore them if deleted by mistake.Key Features * Shows processes locking a file or folder * Allows to unlock, delete, copy or rename a locked file * Allows to kill locking process * Allows to remove locking processes from hard drive * Integrates in to Explorer menu * It deletes files into the recycle bin, so you may restore them if deleted by mistake * Supports both 32 and 64bit WindowsPlatform: Win2000, XP, 2003, Vista, 7 (x86 & x64)Author: Crystal Rich LtdLicense: FreewareWebsite: http://lockhunter.com/---About this release:- This was not a request, but (IMHO) a better and more stable alternative to Unlocker.- Context Menu support is enabled (ShellExt).- 7-Zip SVCPACK Addon (for switchless installer, just extract it from the archive).7-Zip SFX Code (x86):;!@Install@!UTF-8!GUIMode="2"RunProgram="lckhnt32.exe /SILENT /SP- /NORESTART";!@InstallEnd@!7-Zip SFX Code (x64):;!@Install@!UTF-8!GUIMode="2"RunProgram="lckhnt64.exe /SILENT /SP- /NORESTART";!@InstallEnd@!x86 Addon Details (RVMi and nLite compatible):File: beats_LockHunter_1.0b3_x86_Addon.7zCRC-32: 9848b7bdMD4: cc4da555b02c76cdf93269771ccbd927MD5: 6bf95a03865d5d57cfb62262bd07eaf2SHA-1: b0ab2644691b931a96db29d9345809d431330a02Size: 1.17MBDownloadx64 Addon Details (RVMi and nLite compatible):File: beats_LockHunter_1.0b3_x64_Addon.7zCRC-32: a8c02dd6MD4: fef1312d52d806815cf3e392d7a79239MD5: 415dc63cd43fe351064b34cf6a3d034aSHA-1: 4e223bcdc5b60db5fe1c5718dfb3ee0912a45d43Size: 1.26MBDownload
