Unlocker description
Get rid of error message like Error deleting file or folder, cannot delete folder: it's being used by another person or program
Unlocker application was designed to be a very useful Windows Explorer extension allowing users with a simple right-click on a file or folder to easily get rid of error message such as error deleting file or folder, cannot delete folder: it's being u
Helps delete locked files with error messages like:
Posted (edited)
thanks for this jamesbebby ;)
edit: followed exactly the instructions from the 2nd dl by using the exe from the 1st dl but nlite says it's unsupported ... :huh:
Edited by kiki burgh
