Guest LeGend95 Posted October 30, 2009 Posted October 30, 2009 when I put my addons and sp3 with nlitewhen finish setup windows no addons in the windows nothingwhat is the problem?????is that in nlite or in addons? Quote
LUZR4LIFE Posted October 30, 2009 Posted October 30, 2009 (edited) What addons are you using?What order are you building your XPCD? Edited October 30, 2009 by LUZR4LIFE Quote
Guest LeGend95 Posted October 30, 2009 Posted October 30, 2009 this presents of nlite..Nlite.txt Quote
Guest Posted October 30, 2009 Posted October 30, 2009 well try to add addons one by one by the way D:\programs\too\PatchAddon_HIVESYS_v13c.cabthat won't work this addons only works with Rvm Intergator Quote
LUZR4LIFE Posted October 30, 2009 Posted October 30, 2009 I suggest building XPCD by Steps. Starting with removing components. then Adding Service Packs, Tweaks/Patches and then addons. Always check the builds between steps, that way you can what is causing problems. Quote
