shahed Posted November 1, 2009 Posted November 1, 2009 (edited) Hello Guys, I need some help connecting SCSI hard disks to my workstation pc.I don Edited November 1, 2009 by shahed Quote
ccl0 Posted November 1, 2009 Posted November 1, 2009 "wide ultra3 " is the key. you'll be able to find a pci adapter card. you'll also need ribbon cables to connect the hard drives to the adapter. these adapter cards can be a little expensive however. in fact it might be cheaper to just get some ide hard drives. Quote
shahed Posted November 2, 2009 Author Posted November 2, 2009 "wide ultra3 " is the key. you'll be able to find a pci adapter card. you'll also need ribbon cables to connect the hard drives to the adapter. these adapter cards can be a little expensive however. in fact it might be cheaper to just get some ide hard drives.Thanks, i finally got them all working. Quote
ccl0 Posted November 3, 2009 Posted November 3, 2009 wow that was quick. how did you manage to get an adapter card so fast Quote
shahed Posted November 3, 2009 Author Posted November 3, 2009 wow that was quick. how did you manage to get an adapter card so fast I got the adapter from a friend of mine. Its an adaptec ULTRA 160 card. Quote
shahed Posted November 3, 2009 Author Posted November 3, 2009 (edited) Hey rick, I must say, it is very fast, my boot time has also increased with all drivers installed. Its way faster than my Raptor x 150gb, and i think its because of the 15k RPM spindle speed. My system is flying with this drive (148gb 15K RPM). Now am just hoping I can get an SCSI RAID adaptor, so i can Set up using the RAID 0 config (SCSI RAID adpator are too expensive, still on ebay hoping to find a decent cheap one ) Edited November 3, 2009 by shahed Quote
