I've found a weird XP Mode bug. I can install it (and even install apps) just fine, but it only runs after the intial setup. Under the Windows Virtual PC folder under the Start Menu, it just says (empty), unless I have apps installed. Virtual PC is missing, as well as the XP Mode shortcuts that should be listed there. I cant even open the VM directly from the VHD files. Any body else seen this, or have a suggestion?
SOLVED - I upgraded from Vista with Virtual PC 2007 installed. I uninstalled it with a third party uninstaller (VPC 2007 dosent work on 7). It wiped out my start menu shortcuts. XP Mode actually installed fine, I just needed to manually replace my start menu shortcuts.
Edited by hngovr1
