Posted November 23, 200915 yr I tried making an AVG 9.0 silent install and it works great. until i try and install it while Windows installs.. since it's not the exe i assume it's the ini. here is the code on it, Any idea on what i did wrong? [general]builddate=20/11/2009description=AVG 9.0 Free Add-onlanguage=Englishversion=AVG 9.0 Freewebsite=http://free.avg.com[EditFile]I386\SVCPACK.INF,SetupHotfixesToRun,AddProgram[AddProgram]avg_free_stf_en_90_707a1765.sfx.exe
November 23, 200915 yr Keep file names under [AddProgram] in 8.3 format to avoid problems, and do not use 2 extensions (sfx.exe), just .exe will do.
November 23, 200915 yr Author No dice same issue, i'll try and extract the installer see what will happenEDIT: And again no dice... i don't get it.. it wont install as a cab, but it will as a silent install.. Edited November 24, 200915 yr by DeltaCom
