Rota v0.7
Homepage
Readme/screenshot
Rota is simple and easy to use loss-less rotation utility for JPEG image via GUI.
If you take a lot of photographs with your camera while on holidays,vacations,mega events etc,
you will find this utility handy as it can quickly rotate your hundreds of photograhs to the orientation you want.
But rotate only after you move your photographs to the hard-disk as the program runs much faster than rotating directly
from removable media (like SD, Compact Flash card).
Rotav07_addon.cab
Size: 452.46 Kb (463,318 bytes)
MD5: FEA212B64F08AF9388BDAE56959879CD
Thanks to ricktendo64 & DaRk MaDnEsS for their kind assistant, making this release possible.
