Posted November 27, 200915 yr "Resource Hacker" is one of our favorite software which is used to edit various system files like dll, exe, cpl, etc. Most of the times its used to modify Windows look, for example you can change look of dialog boxes, menus, etc.All About Resource HackerNow the good news is, our friend "Angus Johnson" has released an updated version of Resource Hacker which now supports 64-bit files as well as PNG files.That's a major update and every Resource Hacker user should download the new version 3.5.Changes List: * Now decompiles/compiles 64-bit executables * Added PNG image supportAlthough its beta version but its a fully functional and bug free version and can be used without any problem.this will be staying Beta, he only updated the support of 64-bit & .PNG for his own personal use!Added Desktop shortcut & Start Menu entrysinfo. http://angusj.com/resourcehacker/Silent Installlink. http://rapidshare.com/files/312914890/Resource_Hacker_V3.5_Beta_silent.exeCRC32: b70cd439MD5: a42644936f6b11dd79646281e1610956SHA-1: f5cc8fc564f2fe8b3c45cbe96525047d28bdb9d9file size. 628 KBAddonSorry not guna upload the whole file any more just the file 2 make it, All that is needed is a drag & drop of the above exe, and its done.link: http://rapidshare.com/files/312914891/Addon_Files_4_Resource_Hacker_V3.5_Beta.rarCRC32: 45334f78MD5: 9de6b61f13805596187a3792191c3bdcSHA-1: 3a39d6cdd783a3c0f36a7ac607c252b97d00a00afile size: 4.00 KB
