[Addon] Easy CD-DA Extractor v12.0.4.1 (INT)
Easy CD-DA Extractor, the Swiss Army Knife Of Digital Audio is ALL-IN-ONE music converter that rips Audio CDs, converts audio files from one format to another, edits metadata of audio files and burns Audio CDs, MP3 CDs and DVDs, and Data CDs and DVDs
License: Shareware
Platform: WinXP, Vista, Win7
Author: Poikosoft
Website: http://www.poikosoft.com/
About this release:
- As requested by jamesbebby.
- Custom built MSI; supports AD, Admin installs, etc.
- 7-Zip SVCPACK addon (for the switchless installer, simply extract it from the archive).
Notes:
- The original installer used Setup Factory 8.2 by Indigo Rose.
- The Visual C++ 2008 runtime (VC9) is removed, use the runtime addon by Kel or Code instead.
- Multi-language support, default language is set to English.
- Context menu is enabled.
7-Zip SFX Code:
;!@Install@!UTF-8!
GUIMode="1"
RunProgram="EZCDDAX.msi /qb"
;!@InstallEnd@!
Addon Details (RVMi and nLite compatible):
File: beats_EZCDDAX_12.0.4.1_Addon.7z
CRC-32: 8ef68af3
MD4: aea1053b3e28d9537dbf0044d238167f
MD5: b10cdc8918a0038b7cb737d6ac38b544
SHA-1: 884d43342c8609881f50a8b1f31e8b11c299573f
Download
  • 1 year later...
