[Addon] Resource Tuner v1.99.6.1400
[Addon] Resource Tuner v1.99.6.1400 (ENU)
Resource Tuner lets anyone view, edit, extract, and replace strings, bitmaps, logos and icons... All that make up the visual part of your Windows program.
In fact, it allows you to view and edit almost any aspect of a compiled Windows program, from the menus to the dialog boxes to the icons and beyond. Resource Tuner offers exciting possibilities even if you aren't a programmer. It's perfect for translators, tweakers, and anyone else who wants a different look and feel for an application.
Discover the unique features of this Resource Editor , including how to open problem executable files and edit the hidden data which the other editors simply cannot see, wide range of resource types, UPX unpacker, and more. You will learn the industry standard program for translating and customizing the user interface.
License: Shareware
Platform: WinXP, Vista, Win7
Author: Heaventools Software
Website: http://www.restuner.com/
About this release:
- As requested by jamesbebby.
- Custom built MSI; supports AD, Admin installs, etc.
- 7-Zip SVCPACK addon (for the switchless installer, simply extract it from the archive).
Notes:
- The original installer was Inno Setup 5.3.
- Context menu is enabled.
7-Zip SFX Code:
;!@Install@!UTF-8!
GUIMode="1"
RunProgram="ResTuner.msi /qb"
;!@InstallEnd@!
Addon Details (RVMi and nLite compatible):
File: beats_ResTuner_1.99r6_Addon.7z
CRC-32: af13f5cc
MD4: 288c86aff2b0ed6ec0ad25b43d1c0e83
MD5: f2ec2b00b6a2a34f4da032e8eeab1a1e
SHA-1: c84e3c12ff23c8f0924d5c1594c57ca7ccc32f36
Download
