Posted November 28, 200915 yr This is an autoit utility to silently randomize your desktop wallpaper by selecting a picture from %Windir%\Web\Wallpaper folder.It was an inspiration from a post here. I improved the script to accomodate more logic & features.Support jpg, jpeg, bmp & png pictures only. Will only set wallpaper to "Center" mode if image's width fallbelow 70% of your screen width. Most of the time it is using "Stretch" mode. If your picture ratio is same as your screen size, it is "Stretch" mode too.Will not interfere with your theme(s).Access thru Start ->All Programs -> Accessories->Random Wallpaper Changer or Desktop shortcutIncludes 5 randomly selected wallpaper to get you, hopefully inspired to randomize frequently. (Source)Also include to randomize a wallpaper during ROE stage via a batch file.If you do not have ROE items, will still randomize your wallpaper. U will see it during creating desktop...Works on XP only.RandomWallChanger_Addon.cabSize: 1.28 Mb (1,342,725 bytes)MD5: 2C4C45866CE1FAE179A4E7A8AC848AD0 Edited July 4, 201014 yr by Geej
November 28, 200915 yr hi! not to mean any disrespect, but changing wallpaper is just done in a few steps: right click (on Desktop) -> Properties -> Desktop tab -> Browse.... -> Look in: -> (choose an image) Open button -> Apply -> OK. i'm seeing this as either to lessen the slightly tedious step a bit ... or showing how to utilize the power of AutoIt ... either way, this work is appreciated ... let me try this Geej. cheers!
November 28, 200915 yr Author You do it once, you do it twice but you won't do it regularly manually. Too tedious. Besides, there are so many nice wallpaper in the net. Why stick to 1 wallpaper? Changing wallpaper is faster than changing theme. Search & put a lot of wallpaper in Web\Wallpaper to change regularly! I have use another small program (nnCron LITE) to set it to change every 15 minuites. BTW, I'm a fan of autoit. Hope you like it Edited November 28, 200915 yr by Geej
November 28, 200915 yr Search & put a lot of wallpaper in Web\Wallpaper to change regularly! I have use another small program (nnCron LITE) to set it to change every 15 minuites. BTW, I'm a fan of autoit. Hope you like it got lots too in my pictures & \Web\Wallpaper (the latter path i always include in my UA install). i like the idea of changing wallpapers regularly too. i check out nnCron. thanks Geej!
July 2, 201014 yr Author Minor Update:Add autoit code with additional SRandom funcRandomize wallpaper during ROE via batch file.Change 5 random-pick wallpapers (all are 1024x768 res)
