group addons (& switchless installers) & remove shortcuts in start menu
Posted (edited)
hi! i'd like to seek your advice abt the ff:
1. how to create custom group for addons (& switchless installers) in start menu ...
i.e.,: apps A, B & C will be grouped in All Programs -> Utilities (i've requested some from Kelsenellenelvian before & he was very accommodating ... thanks kel! :))
a. with it's own start menu folder
b. with no start menu group (i.e., shortcuts to .exe of apps A, B & C will be together in 1 folder only)
2. how to remove start menu groups & unnecessary shortcuts (i.e., app's website, readme, help, etc.), especially if shortcuts to .exe of apps A, B & C will be together in 1 folder only.
please see some pics below to better illustrate my inquiries:
custom grouping in start menu
shortcuts & start menu folders to remove
thanks!
Edited by kiki burgh
I use a cleanup.cmd that I execute from runonceex for mine.
It looks a little like this:
net user aspnet /delete
DEL "%AllUsersProfile%\Desktop\*.lnk"
DEL "%AllUsersProfile%\Desktop\*.url"
DEL "%USERPROFILE%\Desktop\*.lnk"
DEL "%USERPROFILE%\Desktop\*.url"
DEL "%AllUsersProfile%\Start Menu\Set Program Access and Defaults.lnk"
DEL "%AllUsersProfile%\Start Menu\Windows Catalog.lnk"
DEL /F /S /Q "%USERPROFILE%\Local Settings\Temp\*.*"
RD /S /Q "%USERPROFILE%\Local Settings\Temp\"
mkdir "%USERPROFILE%\Local Settings\Temp\"
MOVE "%USERPROFILE%\Start Menu\Programs\LClock" "%AllUsersProfile%\Start Menu\Programs\Utilities\"
MOVE "%USERPROFILE%\Start Menu\Programs\Other Tools" "%AllUsersProfile%\Start Menu\Programs\"
MOVE "%AllUsersProfile%\Start Menu\Programs\Lavalys" "%AllUsersProfile%\Start Menu\Programs\Utilities\"
MOVE "%AllUsersProfile%\Start Menu\Programs\Smart Defrag" "%AllUsersProfile%\Start Menu\Programs\Utilities\"
shutdown.exe -r -f -t 240 -c "Windows XP will now restart in 4 minutes..."
EXIT
appreciate this Mr_Smartepants! i'll study this. currently, i'm looking into some addons that are executed like what i inquired about. cheers! :)
Hi kiki.
To group my addons I modify the MSI file or use the switch "group" on many installer.
Look sample below:
PDF Creator - a Inno Setup Package
PDFcfg.inf - the configuration file to PDF Creator program
PDF_Creator - the command line to .7z switchless installer
The line Group on .inf file create an custom group called "- Ferramentas -" at start menu.
To modify a MSI file I use Orca editor. Below the AdobeRrd.txt show with create an shortcut to " - Ferramentas -\PDF" in start menu for Adobe Reader 8.
The final start menu are:
- Ferramentas -
PDF
PDF Creator
Adobe Reader
I wait this information help you.
0d
PDFcfg.txt
PDF_Creator.txt
AdobeRrd.txt
