[Addon] Explorer++ v1.0.0.0 INT (x86 & x64)
Explorer++ is a free file manager for Windows. Available on Windows XP and above, it features the same familiar interface as Windows Explorer, while introducing several enhancements and improvements for a much richer file browsing experience.
Features:
* With the option to save to the registry or a configuration file, Explorer++ is completely portable.
* Browse both real and virtual folders.
* Tabbed browsing for easy management of multiple folders.
* Display window shows previews of images as they are selected.
* Easy-to-remember keyboard shortcuts for quick navigation.
* Customizable user interface.
* Full drag-and-drop support with other applications, including Windows Explorer.
* Advanced file operations such as merging and splitting supported.
Platform: WinXP, Vista & Win7 (x86 & x64)
License: Freeware
Website: http://www.explorerplusplus.com
About this release:
- This was not a request, but I don't think I've seen this one before.
- Built MSI's with Wise from scratch, since this application had no installer.
- Added Locale support as suggested by Kees030.
- 7-Zip Addon (for switchless installer, just extract it from the archive).
7-Zip SFX Code (x86):
;!@Install@!UTF-8!
GUIMode="1"
RunProgram="ExplorerPlus_x86.msi /qb"
;!@InstallEnd@!
7-Zip SFX Code (x64):
;!@Install@!UTF-8!
GUIMode="1"
RunProgram="ExplorerPlus_x64.msi /qb"
;!@InstallEnd@!
x86 Addon Details (RVMi and nLite compatible):
File: beats_EPP_1.0_x86_INT_addon.7z
CRC-32: 9a40724c
MD4: 86a2e56b682632d1f06f22f079f6c20e
MD5: b252e449636a0550136f98bb8084caf0
SHA-1: 4e06376f9852ad8e0d081ad704ed79c1a8320485
Download
x64 Addon Details (RVMi and nLite compatible):
File: beats_EPP_1.0_x64_INT_addon.7z
CRC-32: d3f33d95
MD4: e40712ea4b1be7568820d2d35ea9ebd7
MD5: 01e6bab5e463661960cce57c233f3346
SHA-1: 0e1f6ec32c9af016245ba08f211058e870acb4e0
Download
