Lexa Posted December 7, 2009 Posted December 7, 2009 (edited) Hello everybody I'm doing an unattented XP SP3.I want to integrate Internet Explorer 8 to my unattented. So i downloaded an addon to integrate it. It works good , BUT , on the desktop , when I'm doing Properties => Arrange Icons By => Do not display icons on the desktop, it displays this : The message is in french because i'm french so i traduce it to you : Intenet Explorer can't find Html Active Desktop file.This file is necessary to execute Active Desktop.Press OK to desactivate Active DesktopIt seems to be a problem with the dll mshtml.dll . But i dont't understand because there is mshtml.dll in the addon : :g: I try to copy the dll using $oem$ folder but it's the same...Do you have an idea of what's wrong ?(i 'm doing my test on Sun Virtual Box)Best regards,Lexa Edited December 7, 2009 by Lexa Quote
ricktendo Posted December 7, 2009 Posted December 7, 2009 Which addon are you using and on what language source Quote
Lexa Posted December 7, 2009 Author Posted December 7, 2009 Hi ricktendo :welcome: I use this addon => http://www.mediafire.com/?uv4jgc2dezu , i found it in this forum => http://arayashiki.free.fr/phpBB3/viewtopic.php?f=8&t=153The language source of the addon is french and my XP source also Quote
OnePiece Posted December 8, 2009 Posted December 8, 2009 Hi Lexa, test using the Universal UpdatePack/Addon Creator to create the IE8 AddOn FRA, and I think you'll be OKCiao. Quote
Lexa Posted December 8, 2009 Author Posted December 8, 2009 Hi Lexa, test using the Universal UpdatePack/Addon Creator to create the IE8 AddOn FRA, and I think you'll be OKCiao.ok, i' m gone test it thx for your help OnePiece Quote
