Posted December 13, 200915 yr CCleaner with CCEnhancer Description of CCleaner CCleaner is a freeware system optimization, privacy and cleaning tool. It removes unused files from your system - allowing Windows to run faster and freeing up valuable hard disk space. It also cleans traces of your online activities such as your Internet history. Additionally it contains a fully featured registry cleaner. But the best part is that it's fast (normally taking less than a second to run) and contains NO Spyware or Adware! Description of CCEnhancer CCEnhancer is a small tool which adds support for over 900 new programs into the popular program CCleaner. The tool uses the winapp2.ini system built into CCleaner to easily add new rules and definitions for programs. The rules were sourced mainly from the Piriform Support Forum, with several sourced from other places around the internet. Changelog: v5.03.5128 (24 Feb 2015) - Added Google Chrome IndexedDB cleaning. - Improved Windows 10 (build 9926) compatibility. - Improved Firefox and Google Chrome session cleaning. - Improved Unicode support in Startup tool. - Improved keyboard navigation and shortcuts. - Updated various translations. - Minor GUI Improvements. - Minor bug fixes. CCleaner Version: 5.03.5128 CCEnhancer Version: 4.2 Addon Release Date: February 24, 2015 Uninstallable: Yes Credit: *Reaper* NOTE: No shortcuts are created. Right-click recycle bin shell entension only! CCleaner CCEnhancer NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version. - 4.38 MB - 005da8e5d36ae9868c38cd748cae7dd5 Enjoy! Edited March 3, 201510 yr by *Reaper*
October 26, 201113 yr Thank you for the update. The "software souls" lost to the *Reaper* is uncountable.
November 1, 201113 yr great work with addons btw Edited November 1, 201113 yr by Dusana Bojan Djordjevic
February 26, 201411 yr Update request filled. (Updated thread to more clearly show about the shortcuts) Edited March 4, 201411 yr by *Reaper*
June 19, 201410 yr Request filled THX for updating this tool :dancing: Edited July 29, 201410 yr by Camino
February 14, 201510 yr v5.02.5101 (26 Jan 2015)- Improved Firefox Local Storage and Cookie cleaning.- Improved Google Chrome 64-bit support.- Improved Firefox Download History analysis and cleaning. - Optimized Disk Analyzer scanning process. - Improved detection and cleaning of portable browsers. - Updated various translations.- Minor GUI Improvements.- Minor bug fixes.v5.01.5075 (18 Dec 2014)- New Disk Analyzer tool. - Improved Firefox 34 cleaning. - Improved Opera History cleaning. - Optimized Memory and CPU usage. - Improved localization support. - Minor GUI Improvements. - Minor bug fixes.winapp2.ini added folder CCleaner.cabCCEnhancer Edited February 14, 201510 yr by rulman
