HashCheck Shell Extension
Description
The HashCheck Shell Extension makes it easy for anyone to calculate and verify checksums
and hashes from Windows Explorer. In addition to integrating file checksumming functionality
into Windows, HashCheck can also create and verify SFV files (and other forms of checksum
files, such as .md5 files). It is fast and efficient, with a very light disk and memory
footprint, and it is open-source.
Version: 2.1.11.1
Platform: x86 & x64
Addon Release Date: December 3, 2014
Uninstallable: Yes
Credit: *Reaper*
NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version of HashCheck. If your using a x86 system, it will install the x86 version of HashCheck.
Must use Win Toolkit 1.4.1.14 or higher!
Download.png x86 or x64
Size.png - 53.7 kb
MD5.png - 6ba51a4db550d5f7d0519dda3c82b663
Enjoy!
Edited by *Reaper*
  • 4 years later...
  • 4 months later...
Thanks and please help. I added the .WA file to Addons in Win Toolkit 1.5.3.12. When installing image Windows reported it needed file HashCheck x64.dll from CD and asked if I wanted to install from C:\Windows\inf\HCFiles. This folder is present, however empty.
How to solve this?
