Posted December 13, 200915 yr WinRARDescriptionWinRAR is a powerful archive manager. It can backup your data and reduce the sizeof email attachments, decompress RAR, ZIP and other files downloaded from Internetand create new archives in RAR and ZIP file format.Changelog: Version 5.20 1. If Windows User Account Control prevents extracting or archiving commands to create files in system protected folders, WinRAR attempts to start its another copy with administrator privileges to complete the operation. It is necessary to confirm privileges elevation in response to User Account Control prompt to allow such second WinRAR copy to run. 2. You can drag files in Explorer with right mouse button, drop them to some folder and select WinRAR archiving commands in context menu to create an archive with these files in the destination folder. 3. It is possible to use WinRAR.ini file instead of Registry to store WinRAR settings. You may prefer such approach if you plan to install WinRAR to removable media, such as USB flash drive, and then run it on different computers. See "WinRAR.ini file" topic in "Configuration settings" chapter of WinRAR help for details. 4. Added extraction support for ZIP and ZIPX archives using XZ compression algorithm. 5. If ZIP or ZIPX archive contains any compression algorithms except usual "Store" or "Deflate", algorithm names are displayed in "Version to extract" field of archive information dialog. Algorithms with names unknown to WinRAR will be assigned "m<num>" name, where "num" is a compression algorithm numeric identifier. 6. "Open with WinRAR" command is available in Windows context menus for archive formats supported by WinRAR. It can be turned off with "Open with WinRAR (for usual archives)" option in WinRAR "Settings/Integration/Context menu items..." dialog. 7. Command line RAR can read the default set of switches from rar.ini file stored in RAR program folder. Previously it was possible to define only the same set of switches for all RAR command with "switches=<switches>" string. Now rar.ini also allows to specify separate switch sets for individual RAR commands using the following syntax: switches_<command>=<any RAR switches, separated by spaces> For example: switches_a=-m5 -s switches_x=-o+ 8. Command "ch" supports switches -tl, -cu, -cl also for ZIP archives. Previously "ch" allowed these switches only for RAR archive format. 9. For archive formats lacking file time information, such as .bz2, .xz and .Z, WinRAR sets container archive modification time to extracted files. It does not apply to tar.bz2, tar.xz and tar.Z, which use file time stored in tar headers. 10. "Keep broken files" extraction option is supported for bzip2 archives. 11. WinRAR icon in Windows context menus is scaled up correctly in high DPI screen modes such as 150% or 200% of normal text size. 12. It is possible to disable WinRAR "Benchmark" command with "Benchmark" variable of HKEY_CURRENT_USER\Software\WinRAR\Policy Registry key. In multi-user environment "Benchmark" command might abuse shared computational resources. See "Registry variables" topic in "Configuration settings" chapter of WinRAR help for more details. 13. Additionally to "sfxcmd" variable containing the entire command line, SFX module sets "sfxpar" variable containing command line parameters only, without leading SFX module name. These variables are set before starting a program specified in "Setup" command. 14. File overwrite prompt in console RAR displays the size and modification time for existing and new files. 15. When archiving from stdin with -si switch, RAR sets the current system time to modification time of archived file. Previous version did not set this time at all. 16. It is possible to use -si and -v<size> switches together. Previous versions did not allow to create volumes when archiving from stdin. 17. Warning is issued when starting unpacking 4 GB or larger file from RAR or ZIP archive to FAT32 patition, so user may cancel the operation. FAT32 does not support files of such size. Also this warning is issued when starting to create RAR archive with "Store" (-m0) method if estimated archive size is 4 GB or more. 18. "Select all" button in "Settings/Integration" dialog is renamed to "Toggle all". Now it deselects archive formats if all they are already selected. 19. "Delete archive" extraction option correctly removes all .zip and .7z volumes. Previously it removed only the first volume in the set for these archive formats.Version: 5.20Addon Release Date: December 3, 2014Shortcuts created in: WinRAR FolderUninstallable: YesCredit: *Reaper*NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version.Must use Win Toolkit 1.4.1.14 or higher! x86 or x64 - 2.63 MB - 77d348fc9b149d99d9c7bd99eaa4777aNOTE: This will install as a 40 day trial... If you would like to haveit install as registered, just unzip the addon, copy your rarreg.keyfile to the folder you unzipped the addon to overwriting the file thatsalready there, and then rezip all the files....(Note: The .key file that is included in this addon is just a blank fileused as a placeholder by me.. You will need to overwrite it with youractual rarreg.key file if you want this to be registered!)ENJOY! Edited December 4, 201410 yr by *Reaper*
December 13, 200915 yr REAPER, ur like a robot mate, nearly 20 addon posts in like less than 2 hours...lolThanks for all these addons. Your hard works is really appreciated. Edited December 13, 200915 yr by shahed
April 25, 201510 yr https://www.virustotal.com/en/file/c30a45b63480499ec1e83f22ccf7d6c57ec9a7d962e42e3c94837e0322b1f282/analysis/1429947704/ :rtfm: Trogan
