GPU-Z
Description
GPU-Z is a lightweight utility designed to give you all information about your video card and GPU.
Version: 0.8.0
Platform: x86 & x64
Addon Release Date: December 3, 2014
Shortcut created in: Control Panel
Uninstallable: Yes
Credit: *Reaper*
Changelog:0.8.0•Added full support for GeForce GTX 970/980•Fixed BIOS saving on NVIDIA Maxwell GPUs•Fixed GPU memory usage sensor on Windows 8/8.1•Fixed system hang when playing video on systems with Hawaii GPU•Fixed system stuttering on CrossFire with ULPS active•Added support for AMD Radeon R5 M240, R5 M255, FirePro W2100, W4100, W8100, FireStream 9270, FirePro 2450•Added support for NVIDIA Quadro K420, K620, K2000D, K2200, K4200, K5200•Added support for missing Haswell Mobile GPU variant•Added preliminary support for AMD Topaz GPU•AMD Tonga: Fix ROP count, shader count, die size, transistors, product name•Fixed broken HD 7990 detection•Fixed OpenCL detection on some ATI/AMD cards•Added support for PerfCap sensor reason: SLI GPUBoost Synchronization
NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version.
Must use Win Toolkit 1.4.1.14 or higher!
ROG Skin
Size.png - 1.76 MB
MD5.png - 449c0c18f882ce37bf81591ffb6a61c0
Standard Skin
Size.png - 1.69 MB
MD5.png - db9df41c5518f477f2622e2b6e4245a8
Enjoy!
Edited by *Reaper*
  • 3 months later...
  • 1 year later...
  • 3 years later...
