Posted December 17, 200915 yr System Information ViewerDescription'System Information Viewer' is a general Windows utility for displaying lots ofuseful Windows, Network and hardware info - CPU info, PCI info, PCMCIA info, USBinfo, Machine Info, Hardware Sensors, Networked computers, Operating SystemInformation and more.Changelog:Version 4.49 released on 14-Nov-2014 Added support for the original Corsair Link Commander and H80/H100 cooling nodes. Revised the Corsair Link I/O code to use overlapped I/O and timeout the write and read operations after 250 ms. With these changes SIV should no longer stall if the Corsair Link hardware fails to respond to an I/O request. Enhanced Corsair AX760i, AX860i and HX850i power supply reporting. Extend [Link Status] to report any I/O errors. Added Gigabyte 990FXA-UD3 motherboard and International Rectifier IR3564B PWM support. Revised to cache physical memory mappings (MmMapIoSpace()) to avoid high DPC latencies caused when MmUnmapIoSpace() is called.Version: 4.49Addon Release Date: December 3, 2014Platform: x86 & x64Shortcut created in: Control PanelUninstallable: YesCredit: *Reaper*NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version.Must use Win Toolkit 1.4.1.14 or higher! - 4.18 MB - faa60ce5aa134f24483c818b0e56d63aEnjoy! Edited December 4, 201410 yr by *Reaper*
