HWMonitor
Description
HWMonitor is a hardware monitoring program that reads PC systems main
health sensors : voltages, temperatures, fans speed.
The program handles the most common sensor chips, like ITE® IT87 series,
most Winbond® ICs, and others. In addition, it can read modern CPUs on-die
core thermal sensors, as well has hard drives temperature via S.M.A.R.T,
and video card GPU temperature.
Special hardware monitors such as abit® uGuru and Gigabyte® ODIN? power
supplies serie are supported too.
Changelog:Added CPU and GPU utilization.Added DRAM power (Haswell processors).Intel X99 Platform (DDR4 and Haswell-E).Support for Windows 10.New application icon.
Version: 1.26
Addon Release Date: December 12, 2014
Shortcut created in: Control Panel
Uninstallable: Yes
Credit: *Reaper*
NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version.
Must use Win Toolkit 1.4.1.14 or higher!
Size.png - 1.01 MB
MD5.png - 9011f15f48e6ce2e49d714394ded171b
Enjoy!
Edited by *Reaper*
  • 4 years later...
