Posted December 17, 200915 yr Core TempDescriptionCore Temp is a compact, no fuss, small footprint program to monitor CPU temperature.Now Windows Vista and Windows 7 ready! (x86 and x64)The uniqueness of it is that it shows the temperature of each individual core ineach processor in your system! You can see in real time how the CPU temperaturevaries when you load your CPU. It's also completely motherboard independent.Changelog:Version 1.0 RC6 - 9th October, 2013 - New: Digital signature. Core Temp is digitally signed by 'Artur Liberman', it is now easy to tell that you have a genuine copy of Core Temp. - New: Update Checker. Core Temp can now notify you when a new version is available. - New: You can now hide the taskbar button and use the system tray icons to pop the window back up. - New: Added support AMD's new Richland APU. - New: Added support for Intel Haswell and Ivy Bridge-EP CPUs. - New: Preliminary support for Bay Trail-T Atoms. - Fix: BSOD on some Windows 7/8 + UEFI enabled machines. - Fix: AMD FX system freezes/crashes/BSOD. - Fix: Driver failure when closing Core Temp on another Windows user account. - Fix: Corrected detection of certain Xeon processors. - Update: Ram utilization notification icon added to the Settings --> Notification Area. - Update: Logitech G15 applet now supports CPUs with up to 10 cores. - Update: System tray icons' tooltips now display their respective core information. - Update: Log file will now also contain power consumption. - Update: Log file will now keep track of each core on AMD CPUs as well.Version: 1.0.6.0Addon Release Date: December 12, 2014Shortcut created in: Control PanelUninstallable: YesCredit: *Reaper*NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version.Must use Win Toolkit 1.4.1.14 or higher! - 618 kb - cace46252423117782a2c1b0bd42c51dEnjoy! Edited December 12, 201410 yr by *Reaper*
April 26, 201212 yr ty! This is a much apreciated addon, I must say. SystemMonitor (gadget or installer) displays my cpu core speeds incorrectly without it.. LOL.
