*Reaper* Posted December 17, 2009 Posted December 17, 2009 (edited) Autoruns Description This utility, which has the most comprehensive knowledge of auto-starting locations of any startup monitor, shows you what programs are configured to run during system bootup or login, and shows you the entries in the order Windows processes them. These programs include ones in your startup folder, Run, RunOnce, and other Registry keys. You can configure Autoruns to show other locations, including Explorer shell extensions, toolbars, browser helper objects, Winlogon notifications, auto-start services, and much more. Autoruns goes way beyond the MSConfig utility bundled with Windows Me and XP. Autoruns' Hide Signed Microsoft Entries option helps you to zoom in on third-party auto-starting images that have been added to your system and it has support for looking at the auto-starting images configured for other accounts configured on a system. Also included in the download package is a command-line equivalent that can output in CSV format, Autorunsc. You'll probably be surprised at how many executables are launched automatically! Version: 12.03 Addon Release Date: September 17, 2014 Shortcut created in: Control Panel Uninstallable: Yes Credit: *Reaper* NOTE: This is a dual addon... If your using a x64 system, it will install the x64 version. If your using a x86 system, it will install the x86 version. Must use Win Toolkit 1.4.1.14 or higher! - 247 kb - 96e7a333f93f66e4be8b248cf7a5b7ff Enjoy! Edited November 1, 2014 by *Reaper* Muratt, batia1441, crashfly and 1 other 4 Quote
The1anonly Posted January 23, 2011 Posted January 23, 2011 (edited) Update request filled Edited September 1, 2011 by *Reaper* Quote
jgp Posted April 26, 2012 Posted April 26, 2012 (edited) Update request filled Edited May 23, 2012 by *Reaper* Quote
ChiefZeke Posted February 1, 2013 Posted February 1, 2013 (edited) Update request filled Edited February 2, 2013 by *Reaper* Quote
crashfly Posted August 14, 2014 Posted August 14, 2014 You know *Reaper*, this is a great program. You probably do not realize it, but I think you introduced this program to me a long time back. I appreciate the hard work you do. Quote
cavalier3003 Posted November 14, 2014 Posted November 14, 2014 may i have a mirror for last version ? can't download it.thanks in advanced Quote
*Reaper* Posted December 4, 2014 Author Posted December 4, 2014 Latest 12.04 Where? Official site shows 12.03 Quote
Wini Posted February 1, 2015 Posted February 1, 2015 I love this Your Addon-list and special the autoruns -I also have a portable version and made a few PC's a lot faster.It's a great Tool to have in Control panel THX REAPER =) Quote
