oki Posted December 22, 2009 Posted December 22, 2009 Can someone please tell me what resources are used for the logoff screen in XP? The words used are Stand By, Turn Off and Restart.Thanx. Quote
Guest Posted December 22, 2009 Posted December 22, 2009 shell32.dll and msgina.dlljust open with Resource Hacker or Restorator find and change it Quote
pri2sh Posted December 25, 2009 Posted December 25, 2009 mona is right logoff/shutdown dialog images are in shell32.dll and msgina.dll as bitmaps.You can replace it with tools like resource hacker or resource tuner or restorator.be sure you turn Windows file protection off , other wise you won't be able to replace windows file. Quote
Guest Posted December 25, 2009 Posted December 25, 2009 (edited) hi pri2sh you are right but oki say only string"Stand By, Turn Off and Restart" so he need to just find in string table and replace with it.nothis as bitmap Edited December 25, 2009 by mona Quote
LUZR4LIFE Posted December 25, 2009 Posted December 25, 2009 Check this out.This is where I learned a lot about hacking/modding XP files. Quote
