Posted January 8, 201015 yr CAD 2009 EDTION v1.6 For XP by FlawlessWindows 7 Ctrl+Alt+Del styleSwitchless Installer - for RyanVM Integrator & HFSLIPCAD2009v16.EXESize: 13.55 Mb (14,421,560 bytes)MD5: 9B06C3E04504D29850C09CDB395A1784orRyanVM Integrator , N-Lite Addon & HFSLIP:CAD2009v16_addon.cabSize: 13.52 Mb (14,418,495 bytes)MD5: F8F9BC4A47B893DB7F54164B183289E7Uninstallable from Add/Remove Panel Edited January 10, 201015 yr by Geej
January 9, 201015 yr does this pick up from UtCollector's earlier work on CAD 2009 ... i show here that your uninstaller has been included in the .cab.this is appreciated Geej! btw, would you know why resources directory was removed from this release compared to 1.5? Edited January 9, 201015 yr by kiki burgh
January 9, 201015 yr Author I followed Flawless's method of install for v1.6, which he uses batch file. Nothing to do with v1.5(which I did not check it out) or v1.2.In v1.6, Flawless use batch method, w/o providing any uninstall entry.So I need to manually run the batch file to uninstall. So I just repack into an inf & cab, plus following v1.2's uninstall entry.So why resource folder was not there, I dun know. But since v1.6 works w/o resource folder,I guess it is alright. (Maybe Flawless re-programemd his cad2009.exe so he does not need Resource folder) Edited January 9, 201015 yr by Geej
December 10, 201311 yr I installed it. Its working perfectly fine, here I found the information about it. I was already looking for the this edition thanks for giving the link. Edited December 10, 201311 yr by janetkissho
