You can add such an icon by creating a .rc file and add that one to your project. Make sure that the icon file (.ico) resides in the same directory. That .rc file (myapp.rc) looks like.
// Icon
// Icon with lowest ID value placed first to ensure application icon
// remains consistent on all systems.
1 ICON "myapp.ico"
Nice, it working and its easy. And do you know ho i can make my console program invisible? I really need make my Launcher (for patched game) invisible.
EDIT: And do you know how to add files description? Tryied search on google, but nothing found? :crying_anim02: I wan to add company name, description etc...
Edited by George King
Thanks a lot N1K, I also working on Launcher program for Minesweeper. I want to have 90% - 100% working Vista games on XP. I´ve fixed some in Shanghai Solitaire and renamed it completly to Mahjong Titans and made it to looks like Vista/7 Mahjong Titans ;) In Minesweeper it will be hard, because i need to know whats wrong with XML settings file...
Here is source from Mahjong Titans Launcher, it working, but not 100% because if i run the game for first time launching works 100% But if you exit the game and try it run again, you need do it for 2 times => (2x click on mahjong.exe) x2
Mahjong Titans Launcher.rar
P.S. Here is too cold this night if i was smoke on balcony was -22,6 Celsius and in morning was -14,8 Celsius. Brr, too cold...
EDIT: I get a idea. But i dont know how to figure it. My idea is save all from tasklist.exe to TXT file and search for mahjong.exe. As i say, im beginner and i dont know how figure it...
