Posted January 26, 201015 yr Hi, can some one help me with? I really want CMD script which will read all files in folder and make CAB archive with MSZIP compression - i need this compression because i moding ported Vista games XMLs in cardlib etc.
January 26, 201015 yr well you can use cabarc just go to the folderthen type "cabarc x -r test.cab *.*" that should do it
January 26, 201015 yr Hmm, i tried it and it return thisdam i'm dead tired sorry try this"cabarc -r n test.cab *.*"
January 26, 201015 yr Author Yes, this works, thansk, but i need to hvae subfolders into cardlib.cab This command do only CAB with all files...The rigth command is:cabarc -r -p n test.cab *.*Thanks a lot Darky :thumbsup_anim: Edited January 26, 201015 yr by George King
