Geej Posted February 1, 2010 Posted February 1, 2010 This program was made from a post [Trick] How to Set Windows theme from command line by Ken@friThis is an autoit compiled program that select and apply randomly an existing theme. Requirement:1) XP OS only2) At least have 2 themes, excluding Windows Classic Theme must be availableThis program does not check whether your OS has patched UXTHEME.DLL or not.Features:Support console mode. The parameter is the full Theme's filename. XPThemeRandomizer Luna.themeIf Full file name contains space, you need to double quote it. Eg. XPThemeRandomizer "Windows Classic.theme"Access the program thru shortcut created in Accessories Group.Additional features (but disabled):You can adjust the inf for a normal unattended installation & immediately follow up with the program execution with your own choosen theme, either in randomized mode or specific theme in console mode.The supplied inf are included for these possible modes but you need to uncomment out or comment the inf line yourself.Note: This has no effect in unattended installation as the theme you set will be overrided to default (or specified in WINNT.SIF) when you 1st boot to desktop. At the most, only the wallpaper is applied. The only way I know is via RUNONCE key but it has the disadvantage that it requries 2nd reboot to work. Experiment/test this at your own side.XPThemeRandomizer_Addon.cabSize: 567.87 Kb (581,496 bytes)MD5: 4B19198234D3F3A2DAD7D3ECF4A24DE7 Quote
Ken@fri Posted February 3, 2010 Posted February 3, 2010 Seems to be a awesome utility.I take it!Thanx 4 your work :thumbsup_anim: ! Quote
Geej Posted February 6, 2010 Author Posted February 6, 2010 Thanks for sharing your trick too, which gives me the idea to script this. :thumbsup_anim: Quote
Ludmil Etov Posted May 23, 2018 Posted May 23, 2018 I tried to download XPThemeRandomizer_Addon.cab but I get "The key you provided for file access was invalid. This is usually caused because the file is no longer stored on MediaFire. " :-( Quote
