VMware Workstation makes it simple to create and run multiple virtual machines on your desktop or laptop computer. You can convert an existing physical PC into a VMware virtual machine, or create a new virtual machine from scratch. Each virtual machine represents a complete PC, including the processor, memory, network connections and peripheral ports. VMware Workstation lets you use your virtual machines to run Windows, Linux and a host of other operating systems side-by-side on the same computer. You can switch between operating systems instantly with a click of a mouse, share files between virtual machines with drag-and-drop functionality and access all the peripheral devices you rely on every day.
With Workstation, you can take a
I read your post at RyanVM.
Use 7zsplit to extract VMWare.txt, VMWare.7z and VMWare.sfx.
Modify VMWare.txt to your serial, name and others, save file.
Compile back and finish.
0d
0d
thanks a lot i used the sfx method in the end. i didn't know how to compile the file back with that sfx extractor...
  • 4 weeks later...
  • 4 months later...
I'm assuming this installer has been abandoned based on the fact
that no update has been made in almost 8 months. Does anyone have
another resource or suggestions on how to lighten up this massive
installer?
